Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG dishwasher, LD14AT2
Keeps faulting on error IE, but there is water in the machine when it errors. Where is the level switch or a flow switch,
Re: LG dishwasher, LD14AT2
Actually, the Lg has a flow switch sensor and no pressure switch (on some models). flow switch is defective or somehow wet at its connector. also check to see if pump motor is not stuck
Posted on Jul 11, 2008
    New Friend:
  • 67 Answers
The level switch usually a two-or three inch plastic floating device on the base of the dishwasher that looks like a rounded tube. You should be able to pull the top up and down freely otherwise it may be clogged. If you listen closely, you may be able to hear the microswitch inside click as the unit is moved up and down.
Posted on Nov 30, 2007
0 characters
3 Points
IE error code. Any more ideas??
Hello Pete Glover,
According to LG lots of similar problems...
Too much water pressure won't do that... Just the opposite.
LG says you have a water flow issue, kinked line... valve mostly closed... or possibly frozen lines or heavy usage ...
Simply NOT getting sufficient water in to meet cycle requirements
(Mine was caused by a broken water line in our green-house
hogging all the available water pressure (had a full on swamp going and didn't know it)).
Happy hunting
Mar 23, 2016 | LG LDF7561ST
LG dishwasher, it pumps out ok on start up in any program, but gives an OE error
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 12, 2016 | LG Dishwashers
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
Dishwasher LG Model LD 2120SH error IE. What to do?
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
For spares click On:
Jul 19, 2011 | LG Dishwashers
P/No 3850DD 3006E MODEL LDF 681OST 23 7/8 X 33 7/8 609KW2HOO957 69LD 12 10 These are all the numbers on my dishwasher, approx 3-4 yrs old. suddenly started making a noise and stopped washing after...
1. Make certain the water supply valve is turned on. Check the inlet hose for any kinks or bends in the line that could prevent unit from filling properly. Check drain hose for proper installation. If water drains immediately, unit will display an IE Error Code.
2. Check the water supply valve and make certain that it is turned on and open fully or this code will display.
3. Check the inlet valve filter for buildup of mineral deposits. If the inlet valve filter is clogged it will restrict water flow is restricted into the dishwasher, resulting the IE Error. Clean filter with small brush to remove any accumulated mineral deposits that may have accumulated.
4. If inlet hose is kinked, water flow into the dishwasher, is restricted resulting the IE Error. Straighten any bends or kinks in the inlet hose. If the drain hose is not installed properly and the water drains out of unit, this could cause premature draining, which results in IE Error Code. In this case it will be necessary to reinstall the drain hose according the instructions in the installation guide.
5. If the water pressure is not 20 - 120 psi, water will not fill properly. This will result in IError Code. If water pressure is too low, it may be necessary to call for service.
6. During winter, parts of the dishwasher that are installed outside may freeze. Melt the frozen part by soaking a towel in warm water and wrapping it around the part. This should allow the dishwasher to operate.
7. If the unit is not leveled properly, the IE Error may occur. Use a level to check the sides and top of the unit. If the unit is not level, adjust the leveling feet in the front and back. Use the leveling kit packaged with the dishwasher. Check mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
Feb 14, 2011 | LG Dishwashers
Dishwasher has fault code ie
IE fault indicates water fill problem. Check inlet hose not kinked or blocked. Check no water in base activated flood switch. Otherwise, problem will be a faulty inlet valve(can test with Ohm meter), faulty flow meter (measures water intake- cannot test with meter), or faulty control board. Flow meter located on Left hand side of machine- accessed by removing side panel. It has a sensor with 3 wires(red,white,black) which goes up to control board. If inlet valve tests OK (about 4K ohms), and there is no water in base, I would try replacing flow meter assy (comes with housing and sensor complete)
Aug 08, 2009 | LG Dishwashers
E1 error code
Fault is 1E- this indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, but in my experience it is much more likely to be flow meter
Aug 05, 2009 | LG Dishwashers
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher
ok. our machine has done this for 6 months or so, it was ok for the 1st 6 months. i have checked and cleaned and unblocked and gone bloody crazy. today i found the fault and fixed quickly.
the installer stuffed up. the waster water hose must head up and be fixed just under your bench top, then come down hill to your exit/spiggot/drain attachment.
ours was just lying more or less at floor level coming up to the spiggot. so whenever the waste water pump switched off, water would run back into the machine, hence the OE error, and also dirty water with food would then get chucked around it what should have been a clean rinse.
a diagram of the waste water house and how it should be done is in the manual.
i just about blew $1500 on a new machine !!
Jan 17, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
579 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
kieren lowe
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
