I have a CKL36-1H and the fan just seized up. where can i get another one to replaced it with?
    Scholar:
  • 70 Answers
Try running some oil around the shaft and see if it will free up by turning the shaft.If you can take motor apart you can add oil to both bearings if they are of the sleeve and not ball bearing type. What is the brand ?
Posted on Jun 30, 2009
The same thing happened to me last week on my Goodman CKL36-1H air conditioner. I checked the warranty information on the website at http://www.goodmanmfg.com/Home/Warranty/tabid/194/Default.aspx and it said there's a 10 year warranty. You might want to check that also.
Posted on Jul 20, 2009
  • saktuy Jul 20, 2009
    I just tried daddyo742001's solution and it worked for me. Didn't need the warranty service after all. Thanks!!!
How to replace ac blower replacement
the fan blower is located on the opposite side to the drivers side and can be seen if you go to that side and look up from the floor it can be identified by one electrical connector , and the unit is held in by 4 screws and is round in shape . the fan motor is probably seized due to water leaking in or leaves and debris being caught in the vents . make sure to clean out so moisture isn't retained and aids in the rusting of your vehicle allowing water into fan assembly then causing it to seize. some times they can be freed up by rotating the fan blades with unit out of vehicle , disconnect the electrical connector and the 4 screws that retain the unit to repair or replace
Sep 05, 2014 | Cars & Trucks
2006 chevy hhr hvac blower/fan
The fan is normally used for both heating and cooling. Check the owners manual for the fuse location and see if it is blown. If so, replace it and try the fan again. If the fuse blows again, the motor is probably seized and will need a mechanic to oil and free or replace it. If you can get to it your self, BE CAREFUL, and touch the motor when it is turned on. if it gets hot without turning, it is probably electrically OK and seized. If it does't get hot or hum and the fuse is OK, Its either bad or has a problem that will need to be traced. Best to take it to a GOOD mechanic that you trust. Trouble shooting can get complicated.
Nov 20, 2013 | 2006 Chevrolet HHR
Fan stopped working
Without knowing the model, I would first check the fan motor for seizing, then if not seized, I would replace the fan capacitor. (Available at most appliance parts stores or
HVAC parts stores). If this is a motel type PTAC unit (through the wall) I would be looking
at the control panel as the third item to check, as these fail often.
The fan capacitor is a small cylinder with usually 2 wires coming to it and at least one of them come from the fan and has its values stamped on the side.
Hope this helps.
Jul 17, 2011 | Heating & Cooling
I have replaced the cooling fan relay 3 times in the past 4 months and it needs replaced again. How can i solve this problem?
Sounds like the Cooling fan motor may be seizing up when it gets hot causing the relay to fail, try replacing the fan motor & relay.
Nov 14, 2010 | 1999 Jeep Grand Cherokee
My electric fan can turn on for a few second only. what happen?
mcdevito75 here, Sounds like the fan motor is seizeing. Check after the few seconds if the motor is getting hot, if so, the motor is seizeing, replace the fan.
Jul 26, 2010 | Panasonic Dryers
Radiator Cooling Fans won't run. Not seized up.
EIther fuse, relay, fan motor itself, temp sensor, or bad wiring
Oct 29, 2009 | 1998 Plymouth Grand Voyager
The fans in my 1983 nissan sentra just stopped.
It is most likely a pulley that needs oiling or replacement. If fans are ran by a belt, the fan clutch may be stuck or pulley is seized.
If the fans are electric, the motors may have fried or relay is shot.
May 31, 2009 | 1983 Nissan Sentra
Fan making noise squeeking etc
ok not sure which fan or country your in but here in Australia if its the out door fan, should not cost more than $1200  if its the indoor roughly the same depending on access , may cost a bit more for labour but ... ok fan only cost indoor $600 outdoor $450 to $800 depending on weather the fan blade is seized or not, if its seized then a new blade can set you back To the $800 buck mark including the motor
May 11, 2009 | Goodman CLQ36AR49 Air Conditioner
Fridge fan
if fan is has seized and cannot spin freely then fan needs to be replaced
Dec 31, 2007 | Refrigerators
Heating & Cooling Logo
822 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
