Question about Stoves Kitchen Ranges
Recently purchased used whirlpool electric range to replace a gas range. Will not get hot enogh for the eyes to glow red. Takes a long time to cook something, removed the 110 2 wire outlet & replaced it with a 50 Amps 125/250V 3P, 3W outlet. (with only 2 wires) Does that make a difference?
  • 483 Answers
http://www.appliancepartspros.com/bd_whirpool_ele_dryer_parts.aspx
Lokked up the wiring diagram, you might wanna have a look.
Thanks
Fame !
Posted on Jun 30, 2009
The fan oven gets hot but food cooks more on one side than the other. Food needs to be turned for even cooking. Food also takes much longer to cook than stated on packaging.
packaging cooking times is only a guide... not exact
must be an electric range if it slow cooking
thats why professional cooks prefer gas
May 31, 2016 | Kitchen Ranges
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
My Whirlpool accubake is taking a very long time to heat up
It is possible that the igniter that lights the gas is getting weak... as they weaken it takes longer for them to heat up hot enough to ignite the gas. When you light the oven, you should be able to see the orange glow of the igniter within a few seconds (it's similar to a cigarette lighter from a car) within 20-30 seconds you should hear the gas light.
Sep 01, 2009 | Whirlpool Accubake RF362LXTT Electric...
IHAVE A465 and the bake feature does not work all of the time.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 17, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Element Glows Red, can not regulate heat
you have a bad gas valve For that one specific burner. The valve is located right behing the selecter knob. You have to take all the knobs off and removve that plate to access them. You will see a switch. Remove the switch and right there is your valve. You need to turn both power and gas off when doing this repair.
Jan 04, 2009 | Whirlpool RF378 Electric Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Rf 367lxsy range
all you have to do is reduce the oven temp by 25 degrees when using convection. the cooking time will be about 30% faster too so keep an eye on what your cooking until you get the hang on the time differance
Nov 22, 2007 | Whirlpool RF367 Electric Kitchen Range
Kitchen Ranges Logo
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
