Question about Toro Lawn Mower With Toro Power Tools
My zero turn Toro mower Has been very hard to start all season
Some times when running a large puff of white smoke will come out of the tailpipe and the motor will slow down.
I noticed tonight that when trying to start (and had no luck) that the round cylinder next to the motor (I believe to be the oil filter) got smoking hot why trying to turn the motor over.
The mower has both gas and oil.
It is a Toro Timecutter 42.16Z about six years old, and I can't find the owners manual to attempt any work.
Any help will be greatly appreciated.
4 Suggested Answers
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
  • 81 Answers
SOURCE: billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Posted on Jun 19, 2009
  • 2468 Answers
SOURCE: When engaging the deck mower
have you removed the sediment bowl located on the bottom of the carburetor and looked to see if there is a lot of dirt and gunk in the bowl,then while this bowl is off there will be a float (metal or plastic) make sure theres a good supply of gas running out of here where the bowl would normally be,if not,then it could be a plugged needle seat or port in your carb and will need to be cleaned
Posted on Apr 14, 2010
My toro fh 580v smokes when i start it what is causing it to smoke?
hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
May 16, 2014 | Toro Zero Turn Rider 74833 Lawn Mower...
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
Toro timecutter mower motor upgrade
90% of vertical shaft engines use the same pattern only seen a couple that one hole is off place
Sep 13, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Engine foulds out spark plug
if you have a puff of smoke once in a while try valve seals if smokes more times then not do a compression test the rings might be weak
Jul 16, 2012 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
23 hp b&s leaks oil but also as mowing you can see
well if it runs the carb is okay the smoke is just changes in how the carb loads up most of the time unless its not smoking all the time.and most mowers leak from around the dip stick or the crankshaft seals.hope this helps would be curious as to where the oil is coming from.good luck
Aug 26, 2011 | Husqvarna Garden
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air...
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck barterjoe_64.png
Mar 23, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Billows of white smoke when Toro lawn mower runs
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
When truck gets warm it will not run over 45 mph
Puffing white smoke is a sign of a blown head gasket. Coolant is getting into the cylinders.
Feb 17, 2009 | 1999 Ford F350 Regular Cab
Toro Lawn Mower With Toro Power Tools Logo
301 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
