Question about HP Photosmart 3210 Printer
WHAT DOES ERROR Oxf13a0012 mean?
Also 439jm-copy-se-fc.c
How to fix a se error code on a kenwood microwave
Do you mean KENMORE microwave? SE error code typically means a bad control panel keypad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | Kenwood Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Beeps and flashes FC
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective.
Here is the part to order.
Jan 24, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
There is a flashing error code on my keypad - FC. What does this mean? I had a service tech in to repair this problem and he said it was solved. No sooner did he leave and the "FC" began...
If you are not monitored, the FC will come up every time it tries to send a signal to a monitoring station. FC means 'Fail To Communicate" Contact me if you need further assitance
Jul 15, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Hisense air conditioning unit displaying FC, what does this mean?
FC Outdoor low pressure drop. Check your gas pressure. It should be 60 PSI in ambient temp of 98 degree Fahrenheit.
Less gas pressure not only due to gas leak. But also indoor coil and air filter chocked . Service the unit and test again. Helpful?
Jan 02, 2011 | Heating & Cooling
It keeps beeping and shows code FC in the window
hi FC is communication error between boards what that means is wiring harness or power relay board(prb)
Oct 15, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Describe FC error in dawlance 1 ton AC
Its A filter clean indication that means your filters of air conditioner is full of dust and need to be clean.
To clear the FC message, open front panel of your ac and there will be a pinhole switch "Automatic" or "Reset". Keep it pressed for 5 seconds and FC will be removed.
PS: Dont panic if a/c is turned off instantly when you press the button as its normal. Hope it helps.
Aug 22, 2010 | LG LFX25975SW (247 cu ft) Bottom Freezer...
Hola, tengo un celular audiovox fc 9200 y no se
Intenta usar la clave 123, es el valor por defcto de fabrica.
Dec 14, 2009 | Audiovox FC9200
Dialta di 152 error 0L ; i can not print and can't copy.
ol mean there's a door which is open, try to check ur front door and right side cover if its open, dn. if ok, there something wrong with the door swithc
Nov 11, 2009 | Konica Minolta DiALTA Di183F Copier
Beeping noise - letters appear fc
Christina, FC means there is a communication error between your main power board and keyboard. There is a J2 harness that runs between them. You might try to reseat this harness. If that doesn't work the main board will have to be replaced. Catriver..post back.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
HP Photosmart 3210 Printer Logo
67 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
