Starlogic MA9WBK Won't turn on.
I have a Starlogic MA9WBK 19'' TFT LCD Monitor that won't power on. The unit started having problems a few weeks ago. It became more and more difficult to turn it on after the power had been turned off until the unit wouldn't turn on anymore. I have disassembled the unit and don't notice anything unusual or obviously damaged. When the unit is plugged in, it makes a soft popping noise from the speakers. This sound doesn't go away immediately after power is removed, instead it takes a minute or two.
SOURCE: 19" starlogic monitor
CURRENLY MY LCD MONITOR FROM STARLOGIC SHOWS DISCONNECTOR MESSAGE? wHAT IS THE PROBLEM...
Posted on Jan 15, 2008
SOURCE: Polaroid 37 in LCD TV
There is not a good solution. If you read about the Polaroid 37" LCD HDTV, you have a problem and it's the same one that many of us have. According to Polaroid's service center, the control box needs to be replaced. Polaroid does not stand by this product. The company gives you a lot of lip service about how many they sell and how few problems they have - they're lying. The TV's should be recalled and I'd suggest you join many of us to demand it. Write BBB, write the company where you bought the TV, write any consumer group you can think of - Polaroid TV's are junk. Sorry you've got one. Sounded like a good deal and Polaroid used to manufacture quality - no more.
Posted on Apr 20, 2008
VOTIT
  • 2071 Answers
SOURCE: tv problem
Your problem is in HOT, Horizontal output transistor is defected already ,this is high voltage transistor , if no high voltage there no picture ,but supply is there because light is flashing ,the supply voltage is trap ,when this voltage go to horizontal section your tv is automatically shut off because defected HOT,,you change this transistor ,so performance will better again ..find a tv repairman to do the works in changing the transistor and little reheating works.
This is better in order to avoid high voltage shock,this not cost much....
Posted on Jun 26, 2008
Fix-4U
  • 293 Answers
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: Making Loud noises
sounds like the yoke on us. yoke is what makes that nosie.
Posted on Sep 13, 2008
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
My 19" TFT LCD monitor
Power capacitor problem, needs taking to a qualified TV repairshop to have the capacitor replaced / checked
Dec 28, 2010 | Xerox XA7-192i 19" LCD Monitor
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
Gateway FPD2185W TFT LCD MONITOR
The backlight or inverter is going out on your screen.
Eventually it will just stay dark. You will need to replace one of the two if plan on keeping monitor.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Push button power broke Starlogic LCD 19"
My monitor Display show to wide.
Starlogic 19'
Nov 07, 2007 | Star Logic 17" LCD Monitor
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
