Question about Samsung HP-R4252 42 in. Plasma HDTV
Bottom half of screen is black
I have a 42 inch Samsung Plasma. The bottom half of screen goes black (intermittently). Sometimes instead of black, it turn into pastel colroed vertical stripes. It goes away for awhile if we turn the set off and then back on in a few minutes, but then the problem recurs.
  • 744 Answers
Its ur diaplay problem.. go for a change of new display...
Posted on Jun 30, 2009
Top half of my screen goes white and pink intermittantly. All channels. HDMI input. Samsung 42 Inch plasma
First try using Component cables instead of the HDMI cables and see if that fixes the problem. If it does then you have a bad HDMI cable. If it does not then you might have a bad Y-Main bd or X-Main bd or a Main bd. It can also be bad buffer bds. Have a trained Samsung tech look into the problem.
Jul 15, 2009 | Televison & Video
Screen Problem
hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it?  When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
Feb 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
42 inch samsung plasma screen is half blacked out
the problem lies in the y or x board just replace the on thats acting up and you should be ok
Dec 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Jun 24, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Screen Problem
I have been trying to fix one of these tvs and found out from a repair man that the lower half going blank means a problem with the lower buffer. and that is also what the manual I downloaded says.
have you checked that?
Dec 07, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung HP-R4252 42 in. Plasma HDTV Logo
801 people viewed this question
Jerry Greenberg
Jerry Greenberg
