Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Logo
A
Anonymous Posted on Jul 25, 2014
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
Danny Hopper
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Aug 05, 2014
Danny Hopper
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
15641
Points
46
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
3 Related Answers
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jun 13, 2009
SOURCE: PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
wcdoc1953
wcdoc1953
  • 280 Answers
  • Posted on Nov 04, 2010
SOURCE: My wife's Pride Legend scooter
There a several solutions to this problem and all involve removing the seat and rear cover of the drivetrain. The brake and lever arm of the brake is located on the end of the black motor. Moving the brake lever up and down places the motor in freewheel or locks the motor/brake. There is a connecting rod from the brake lever to a ball that can be pulled up or down where it exits the back cover.
The connecting rod and brake lever may be bent making it difficult to work. Gently bend it back into alignment if you can. Be careful not to damage the brake and brake lever. The rod is easily reshaped. There is also a chance that the mechanism is binding and rusted or loose. You should be able to work the rod easily. See if you can move the lever right at the brake.
The more likely culprit is an overheated seized brake with the only solution replacing the brake. I have also seen the hexagon shaped nut which is secured by 2 set screws onto the motor shaft inside the brake housing come off. The set screws get loose and the nut gets lodged in the brake. Both of these solutions requires removing the brake with some allen wrenches after noting its position on the motor shaft. Hope this helps.
Colin Taylor
  • 347 Answers
  • Posted on Nov 15, 2011
SOURCE: battery stuck in pride gogo mobility scooter how to remove
Hello Bruce,if you contact a local dealer for your scooter.Ask them to download you an owners manual,there will more than likely be a small fee for this.Alternatively visit the Products website & ask the same question,this may be a better option as there may be no fee.They could send you 1 in the post.I hope this has helped you,Colin.
We just changed batteries. When we put the key in, there are 5 beeps and nothing will move.We have pushed the brake lever on the back forward and still nothing.
Hi I have no data on the go go ...if the circuitry is similar to pride x the 5 beeps mean the manual lever is in freewheel u have to remove key put freewheel lever in drive & replace key good luck
How do I oil the freewheel mechanism located on the trans-axle
hi, is it noisy ? , i don't advise you doing that , they get noisy as they wear but in most cases they do not need to be open up , it';s tricky and i advise you to let someone who skilled in that to do so...
Regards
Rob
www.gewizrepairs.co.uk
Pride gogo think is in freewheel when it isn't
There is a micro switch that the lever engages to tell the controller the position of the lever. It's either not closing properly or is defective.
Have GOGO scooter, when you turn it on the alarm sounds and will not to anything, it has been fully charged.
Princess try the freewheel lever make sure its in the drive mode and turn the scooter back on Hope this helps
6helpful
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
3helpful
Beeps when in drive won't move
How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
I have a Pride Gogo 3 wheel scooter. Suddenly I cannot get the 'freewheel' mode. Any suggestions please?
the lever at the back may be slack and missing the turn-point. Try moving up and down a few times, very gently, this may get the correct position,.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
