I have the lg 47 lcd and i had the same problem for about 1-2 months ,but out of the blues the sound just got really louder ,i think the speakers broke in and it the sound normalized.But my tv sounds great now , my kids even asked me if i did something. Maybe just give it a little time.
Hello Collin, the problem that you will have that the replacement strips correspond to a lower screen size, you could have less illuminated areas, another problem would be the work tension, surely the 42 "strips have less LED than the 47, therefore the strip of 42 "would be working with a feed voltage calculated for the 47"
I suggest you try to get the strips for the measure 47 ", change them all, they are new, because for this work you must remove the LCD panel, very fragile element
I hope you can solve the problem
Greetings Franco Dosil
Hola Collin, el problema que vas a tener que las tiras de reemplazo corresponden a una medida de pantalla inferior, podrias tener zonas menos iluminadas, otro problema seria la tension de trabajo, seguramente las tiras de 42" tienen menos LED que la de 47, por lo tanto la tira de 42" estarian trabajando con una tension de alimentacion calculada para la de 47"
Te sugiero trates de conseguir las tiras para la medida 47", cambialas todas, que sean nuevas, porque para este trabajo debes retirar el panel LCD, elemento muy fragil
Espero puedas resolver el problema
Saludos Franco Dosil http://gscs-b2c.lge.com/downloadFile?fileId=KROWM000580073.pdf http://gscs-b2c.lge.com/downloadFile?fileId=KROWM000572310.pdf
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
That is most likely a bad diode in the power supply. It will require repair but it should be reasonable. There are youtube videos showing the repair if you are handy.
Im not 100% that this is the cause, but it seems like it
If you hit the studs I would use a 7/16th lag screw at 2 1/2 inches. Not to make this sound like I am guessing, I put these up all the time for work. The lags should be included with the mount though.
