Question about Wise Solutions Wise For Windows Installer 6 Enterprise Edition for PC
I tried to load i tunes onto my computer. started to load through windows installer and then stoped. Sayed that either windows is running in safe mode or windows installer is not correctly installed. What to do
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 52 Answers
To resolve this, the following always works :-
Start, then Run, then type regedit
Go to HKEY_LOCAL_MACHINE\SYSTEM\CURRENT CONTROL SET\SERVICES\MSIserver\WOW64
Right click on WOW64, then select Modify
Set Value Data to 0
Close regedit & reboot the computer
Posted on Sep 22, 2010
How to turn off safe search
Safe Search is a bad piece of malware that is part of the SafeSearch toolbar. You or someone who used your computer allowed this toolbar to be installed, possibly without realising it.
You may be able to boot up your computer in Safe Mode. Tap the F8 key repeatedly when you turn the power on. After booting into Safe mode do a search for "windows defender". If Windows Defender is there, try running it to remove SafeSearch. Also, there are 2 good malware cleaners that will remove SafeSearch and the toolbar along with it. The cleaners are AdWCleaner and Malwarebytes. Both are free. You can download either one or both from www. majorgeeks.com (Majorgeeks.com) . Try starting your computer in "Safe Mode with networking". On most computers (except Windows 8) repeatedly press the F8 key on your keyboard right after you turn on the power and before Windows starts to boot up. When in "Safe mode with networking" you can download and install the cleaner. Or, you can download the cleaner on another computer and save it onto a USB flashdrive and plug in the flashfrive to your computer and run the cleaner install from there. Or, go online in Safe mode and go to Housecall.com.
Aug 17, 2014 | Intel Computers & Internet
Question ashbassili asked on Office 2007 setup.exe can't find setup controller file - either network error, error reading DVD or problem with the package. This is a fresh install off a DVD. Onto a
Sounds like it's a compatability issue. Try right clicking the .exe setup file and choosing run in compatability mode. Or you could try right clicking the .exe setup file and going into property's, run in, and choose run this file in Windows xp service pack 2 mode. Apply the changes and try again. If that still won't work make sure your PC is fully upto date and has all net framework packages installed. A lot of programs refuse to install unless you have all the necessary updates and frameworks and Java installed. It doesn't specifically tell you the problem. Just gives you an error on install.
Apr 26, 2017 | Microsoft Office PowerPoint 2007 Upgrade:...
Windows 7 on my laptop
Try to Start PC in The Safe Mode by Pressing F8 Continuously,Before the Windows 7 Boot Up Screen Appears,
then Select Last Known Good Configuration and press Enter,
that should Save ur laptop,
if the Problem Persists,Try to Boot on Safe Mode,if that also Fails,try to repair ur OS files using Windows 7 DVD.
May 12, 2013 | Computers & Internet
The MSI wind netbook constantly remains on the windows XP start up screen as if it is loading but then nothing happens, I have tried starting it in safe mode but it just lists lots of program lines??? It...
Windows start up file corrupted. If you cannot access it through safe mode, you will need to reinstall or do a repair install of windows. As this netbook has no DVD drive ( as far as I can recall), you will need to EITHER boot from an external USB DVD Rom drive, OR if you have not got one of these, then you will need to go onto another computer, download this:
http://wintoflash.com/download/en/
Follow these instructions:
http://www.youtube.com/watch?v=_SwZDboRv6U
Jan 24, 2011 | MSI L1350430US Netbook
I'm try to install new window 7 64 bit into compaq presario c700 ,but load and stand after window load. it says window starting and nothing happen.
Hi there !
If there is problem on loading you window 7. Try to run it on safe mode by pressing F8 when starting to reboot your computer. When running on safe mode, windows will automatically fix some error regarding some loading problems.
After press F8, just choose run on safe mode and it will read and fixed all errors on drivers. Computer can crashed because of faulty drivers installed or too many same drivers installed. This solution will fix your problem.
I hope it helps you. Thank you for using FixYa !
Jan 09, 2011 | Computers & Internet
Hello and thank you for reading, My computer won't stop rebooting itself regardless of what hard drive I plug in, it gives me the "Windows didn't start ... please use the up and down keys to choose...
When you say "regardless of what hard drive I plug in" worries me.
If you didn't install windows on the hard drive you're using while it was in your computer it won't work. Windows needs to see all devices as it is installed.
My best guess for you is to install windows again onto a hard drive.
Failing that you could download one of the linux O/S, say UBUNTU, and that will load onto your pc without installing so you can look at the data on the HDD's.
Finally there's the ultimate boot for windows CD which loads a windows shell onto your PC without installing and provides loads of diagnostic tools.
Both the last two items are freely available to download at the end of a GOOGLE.
May 01, 2010 | Computers & Internet
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
Installed webroot not compatiblewith windows 7
the antivirus that u installed is stoping some critical windows files getting loaded...as it sees these DLL files/exe files as potential trojens/virus....the same issue is with Avira Antivirus....try useing Mcafee or AVG AV...they r good free AVs....
to get ur desktop....when u boot press F8 and if get to the option screen...chose Safe mode to load windows...if u get to work in Safe mode.....uninstall the Webroot AV...and run a chkdsk in DOS prompt...
to go to dos prompt...do this
Start / Run / type cmd there in the box...in the balck screen....go to c:\
type cd windows
type chkdsk
after chkdsk is complete shut down and restart...
this should fix...
then install AVG or Mcafee
Dec 25, 2009 | Computers & Internet
Black screen nothing loading
One of your driver is acting up. start in safe mode, disable one of the drivers (DVD or whatever) then close and try to start normally. If the PC starts then reinstall the driver.
Aug 10, 2009 | Lenovo 3000 C200 Notebook
Black screen after loading windows logo
If you buy new then you don't need to install Windows XP
If you buy used then you need to reinstall all drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=1817059
Boot into safe mode then you install all drivers
Sep 16, 2008 | Compaq Presario V5102NR Notebook
Open Questions:
Starwars Battlefront 2: Wont Install I just finished downloading Starwars Battlefront 2 from: http://www.warez-bb.org/viewtopic.php?t=5343241&highlight= It says I need these requirements to play: (The words in the brackets are what I have) Operating system: Windows 2000/XP (Windows XP) Processor: Pentium 4 1.5 GHz (Genuine Intel(R) CPU 2140 @ 1.60GHz [2 CPUs]) Memory: 256 MB (1024MB RAM) Video: 64 MB (512MB) Sound card: compatible with DirectX 9.0c (DirectX 9.0c ) Available at Railway: 5.5 GB <- What does this mean? CD-ROM speed: 8x <- How do I check? Do I meet the requirements? I extracted it; opened up the file and inside there was 4 files: Disk1(712,674kb) Disk1(1kb) Disk2(367,454kb) Disk2(1kb) They are all MDF files. I open either of the Disk2 files and it has junk like DirectX, Docs, some setup-2.bin file? I open either of the Disk1 files and "Starwars Battlefront 2 Autorun" opens, it has four options, they're all in a very weird language, and only 2 of them are clickable.. The second one gives me this: ýòàïû çàïóñêà èãðû 1 - óñòàíîâèòå èãðó. 2 - ïåðåçàãðóçèòå êîìïüþòåð. 3 - çàïóñòèòå èãðó, ïðè ýòîì ïîÿâèòñÿ äèàëîãîâîå îêíî. 4 - íàæìèòå êíîïêó KPAK è çàêðîéòå ýòî îêíî, íàæàâ êðåñòèê â ïðàâîì âåðõíåì óãëó îêíà. 5 - èãðà çàïóñòèòüñÿ àâòîìàòè÷åñêè. I think it's a readme.. The first option opens an installer.. it's in that language.. I run threw the installer and it begins to installer, but halfway threw I get an popup.. I think it's asking me where I want to save something.. It has a bar where i'm suppose to put a path, the default is G:\, when I click ok is has ???? "setup-2.bin" ???? "G:\" ????. The ?'s meaning the random language.. I click browse and click on other options but it has the same result for everything.. Please help somebody!
May 06, 2010 | Wise Solutions Wise For Windows Installer...
Wise Solutions Wise For Windows Installer 6 Enterprise Edition for PC Logo
153 people viewed this question
Top Wise Solutions Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wise Solutions Computer and Internet Expert? Answer questions, earn points and help others
