Question about Magic (ED8000) Professional Microphone
I can see the tv but it doesn't sound - Magic (ED8000) Professional Microphone
  • 744 Answers
Hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jun 30, 2009
Luxor tv
There is a short ciruit inside its circuit board. It sounds that the horizontal output transistor has gone leaky.
Jun 06, 2013 | Televison & Video
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
My tv blacksouts with no picture but has sound?
tried with resetting doesn't work?totally black screen or has a white screen display?
Sep 30, 2012 | Samsung PN50B430 50 in. TV
Hi i need to know what cable i need to conect my lap top to tv ? my lap top is a dell latitude d610
Depends what your TV supports. You could do vga to hdmi cable if your tv is newer, this will only do video since vga doesn't support sound. You would need a headphone jack to whatever your tv supports for sound adapter.
Dec 29, 2011 | Computers & Internet
My sound disappears
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Nov 11, 2011 | Televison & Video
Tv sound only plays with dvd player not television.
problem in audio-video ( audio pin). clean this with tooth brush from inner site.
Jul 02, 2011 | Sanyo 42K30E 42 in. TV
Samsung hdtv, I have sound but no picture. This is an older tv, I have had it for about 6 years.
Have you try watching using a DVD player on your t.v if doesn't try watch on it using a DVD player but if still it doesn't have a picture but only sound perhaps there is a problem with your HDTV.
Jul 01, 2011 | Samsung PCL5415R TV
I have the lg dvx640 and the TV 42ld450 but I can't seem to get any sound out of either appliance when connected together. But I do have picture. Also my av scart cable doesn't fit into my TV...
If the cable does not fit and you are not getting sound when plugged in. It is most likely the cable. Check the pins to see if they are in-tact and are not bent or worn. If you have a spare, try that. If you can plug the cable into another tv and it works then... back to the drawing board. Post back and let us know if the cable is not the problem.
May 23, 2011 | LG Televison & Video
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Magic (ED8000) Professional Microphone Logo
88 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
