Question about Denon AVR-1907 Receiver
Hi with my denon avr 1908 can i run video through HDMI cable and sound trough Coaxial cable so i can get 5.1 surround from my sky HD box
  • 119 Answers
You can get 5.1 using HDMI connection.
other wise in the set up you can configure the denon to not use the hdmi audio and configure that input to use coaxial or optical all digital inputs allow for 5.1 once all connections are made on the front of the unit find the input mode button and select auto
Posted on Aug 02, 2009
I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the 1611..........Johnmoondancer@hotmail.com
Mar 06, 2011 | Audio Players & Recorders
Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Apr 08, 2010 | Denon AVR-1908
Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Mar 05, 2010 | Denon AVR-1908
Just connected sky via hdmi through denon 3310 and no sound is coming through the tv. Also do i need to have amp on to view sky via hdmi?
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Nov 22, 2009 | Denon AVR-3805 Receiver
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Denon AVR-1907 Receiver Logo
302 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
