Question about Motorola Mobility RAZR V3
How to turn off speaker
A friend used my phone and the speaker turned on and I don't know how and I also don't know how to turn it off
  • finckk Nov 08, 2007
    After I opened the phone and pressed the button THEN it worked. Thanks
  • 60 Answers
There should be a button on the top part of the screen on the left hand side. Press the button and hold it and it should say speaker off.
Posted on Nov 08, 2007
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
Surround sound unit turns off right after I turn the system on and can not get it to stay on !!! I left for vacation came back and now the unit will not come on for more than 4-6 seconds ! My friend said...
Hi Ninh,
I had a similar problem with my stereo receiver not long ago. The problem ended up being a short in one of the speakers. If your speakers are powered separately from the receiver, it might be that one of them was damaged due to the storm. The short would cause the amplifier to shut down as soon as the speakers are turned on.
The easiest way to check this is to disconnect all the speakers, turn the surround sound on and then reconnect them one at a time to find which speaker is causing the problem.
Hope that helps.
Jeff at Remotes.com
Apr 14, 2017 | Televison & Video
E315 cerwin vegas speakers and one keeps blowing a fuse when I turn it up to the normal volume I play them.Can I use a bigger fuse or is it the speaker?About a yr old rarely used until the last few mo
Try playing the speakers at a friends house or something to see if you blow their fuse. If you don't then you know for sure that you need a bigger fuse, but if you do then it's the speaker.
Jun 03, 2013 | Audio Players & Recorders
Can't play Words with Friends. Help.
Where are you trying to play it at? Assuming you are using a wifi connection, wherever you are getting wifi access at has blocked it. Try turning wifi off and using your data instead.
Feb 17, 2013 | Compaq Computers & Internet
Just bought a Harbinger HX121M 2" Monitor, from Musicians Friend it did not come with a booklet on how to wire into my sound system it has two 1/4" jacks and a strange round plug about the size...
If you don't know how to connect this... well we don't either because you did not tell us what your sound system is. The larger plug is what is known as a "Speakon" connector and is a fairly reliable speaker connection that is used now. For your use you will PROBABLY use either of the 1/4 inch jacks with a cable from the amp that will drive the monitor(s). If you have multiple monitors you will daisy chain them using the 1/4 inch jacks and SPEAKER rated cables creating a string of speakers with input going into one and an output from the same one to the next speaker and so on...USUALLY you will be limited to two speakers per amp output...
Aug 15, 2011 | Harbinger HX121M 12" Stage Monitor
I got a old phone from my friend because my phone got broken. and when i went into the security code set up, i thought the security code was 0000. but it was wrong and it asked me about the puk codes and i...
You have entered the wrong SIM password so it is locked. You can unlock it easily. You have to call your network service provider and ask for PUK code. They can ask you SIM no. which is printed at the back of SIM card.
Then you can enter the PUK code and use the phone again.
Revert in case of any problem.
Jun 14, 2011 | Nokia Cell Phones
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
Phone stays on speaker phone. How do I turn off
while you are in a call and it says that, you should be able to press a button, possibly says on the screen to go back to normal, its a feature that generally comes up when you are in a call, its turned off and on by a press of a button.
Sep 12, 2009 | Uniden DECT 6.0 Cordless Telephone...
The speaker stopped working!
hi im josh a mobile phone technician in cebu phils, may i help you? Friend if that would be your prblem that your speaker won't work then that is very simple.A speaker is a hardware in the cellphone that cannot be damage easily but always be foreseen as damage because it is very sensitive especially when the phone was dropped. Friend the problem of your  speaker is only a disconnection the filament of the speaker to the board is disconnected or misaligned. all you have to do is firmly screwed the phone properly and dont use casing the may tighten very much your phone coz this may cause disconnection.just tighten firmly correctly the screw of the phone.it will solve the problem. good luck. vote me so that i will know if i helped you so.thanks
Feb 23, 2009 | Nokia 6030 Cellular Phone
Whan i turn it on it says please wait...
i would take it to your nearest phone shop and ask their advise!
or just shout at it!!
lol
good luck!
Apr 02, 2008 | Sony Ericsson K800i Cellular Phone
Motorola Mobility RAZR V3 Logo
509 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
