Question about Haier 65-Pint Dehumidifier
Filter Removal How in the world do I get the filter out of this unit?
  • 33 Answers
I believe that this unit has a permanent filter, and can not be removed to clean. You should however be able to access it to clean it. Hope that helps!
Posted on Jul 29, 2009
Why does it freeze on occasion?
coils on these units should not freeze 1st ill bet that production of water removal was not up to par so you turned setting down this makes unit work longer without a rest (cooldown) period (not good) so now the gas charge might be low (from overheating ) and/or filter will require more frequent cleaning
Oct 19, 2014 | Dehumidifiers
After an hour, the refrigeration unit begins to freeze up. Condensation appears on top of the dehumidifier cabinet. I have eliminated all obstructions to air flow, including the filter. What can I do?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Sep 10, 2011 | LG LHD45EL Dehumidifier
Starts then stops completely showing this type of line - - - - where humidity should be. Cannot turn on or off.
The ---- lines you see, indicates that water collection bucket is not installed properly, as well as the air intake filter may need to be removed and cleaned.
When installing the bucket, be sure that it fit's "squarely" into the holder from top to bottom, so that it makes good contact with the bucket safety removal switch. When installed properly the bottom of the bucket will not tilt down at all.
To clean the filter. turn the unit OFF & unplug it. Remove the bucket and then pull the filter straight down and out. The filter can be vacuumed or if it's really dirty, wash with warm water and mild dish washing detergent. Rinse thoroughly, shake off any excess water and thoroughly dry, before reinstalling. Never operate the unit without the filter in place.
Hope this helps you and thanks for choosing FixYa.
Sep 06, 2011 | LG LHD45EL Dehumidifier
Put empty bucket in,it runs for minute,then shuts off. need a switch that won't shut off. Where could I find one my zip code is 44451.
The switch may not be the problem. However, a dirty or clogged air intake filter or the humidity extraction level set to high could be.
Turn the unit OFF & unplug it.
Remove and clean the air intake filter thoroughly. Be sure the filter is completely dry, before reinstalling. Never operate the unit without the filter in place.
After the filter is dry, reinstall it, plug the unit and turn it ON. Lower the humidity extraction level to 35%. If you have an analog unit (No LED screen) set the humidity extraction knob on Maximum.
And finally, be sure that the water collection bucket is installed properly and is not vibrating loose when the unit runs. It should fit squarely into it's holder, making contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly, it should not tilt down at the bottom of the bucket.
All of the above should solve the problem and you won't need to purchase a new switch. But, in the unlikely event, that you will have to. You will need to furnish the Brand Name of the unit and the Correct Model Number. As, they are not all the same.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
No moisture removal. This is a DDH 30 model. How does one game access to the air filter for cleaning. I realize this is an older unit but has always performed well. Before purchasing a new...
Wayne, the filter may be in one of two places.
1. Turn the unit OFF & unplug it.
2. Remove the bucket from the holder. Look up inside the holder, just in front of the louvers and you may see a plastic pull tab type handle. This will be the handle to the filter frame. Pull it down and out of the unit. Since it sounds like it has never been cleaned, wash it in warm water and dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter in place, as it could cause damage to the unit
2. If the filter was not located in step 1, on the right side of the unit, just behind the louvers, there may be a pull open trap door. Flipping that door open, will give you access to the filter and it's removal. Clean it as described above.
The above are the only 2 places I know of, that the filter can be located in on a Delonghi
Dehumidifier. Unless, your unit is over 10 years old. In any event, I hope this helped you.
Jul 06, 2011 | DeLonghi Dehumidifiers
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
Jul 03, 2011 | Dehumidifiers
Is there a filter in the 65 pint dehumitifier and if so how do i clean it!!!
Yes, there is a filter in it or it should be. Since you didn't say which model you have, it is in one of two places. Before attempting the filter removal turn the unit OFF and unplug it.
1. It can be accessed by removing the bucket and just inside the bucket holder at the top, behind the louvers on the front, you will see a tab type handle. This is the frame for the filter. Pull it down to remove the filter.
2. There will be what looks like a pull door on the right hand side of the unit, behind the louvers. Pulling straight out on that will remove the filter.
The filter can either be vacuumed to clean it or if it's really dirty, wash it in warm water & dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter installed, as it could cause damage to the unit.
Hope this helped you. Please let me know. Thanks.
Jul 02, 2011 | Haier 65-Pint Dehumidifier
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Just stopped working. When I turn unit on the power light comes on for about 2 seconds then goes off, nothing else happens. Any ideas?
It may simply be that the water collection bucket is not installed properly or the air intake filter is clogged.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Remove the air intake filter and clean it, if necessary. While the unit is unplugged and OFF, remove the water collection bucket and reinstall it. Making sure that the bucket fits "squarely" from top to bottom, in the bucket holder. It must make contact with the bucket safety removal switch, to activate the unit. Once you have reinstalled the bucket, make sure the bottom of the bucket is not tilting downward.
If you cleaned the filter, be sure it is totally dry, before reinstalling it. Then plug the unit back in, turn the Master ON/OFF Switch to ON and if everything was done correctly, the unit should start and run. DO NOT OPERATE THE UNIT, WITHOUT THE AIR INTAKE FILTER INSTALLED.
Hope this helped you to troubleshoot and solve the problem.
Jun 18, 2011 | Maytag Dehumidifiers
My lg dehumidifier is collecting ice on top and no water is collecting in waste. Is it dead? this is a new problem but machine is not old
Sounds as if the air filter may be clogged, which causes the coils to freeze. Unplug the unit and allow it to thaw. Once thawed, follow the Owners Manual"s instructions on accessing, removal and cleaning of the air filter. That should solve your problem.
Mar 01, 2011 | LG DH404E Dehumidifier
Haier 65-Pint Dehumidifier Logo
229 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
