Question about Pioneer VSX-453 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I have a Pioneer VSX-453 surround reciever and want to connect a sub-woofer for my surround system. There is no Sub-woofer outlet. How can I connect this?
Re: Connecting a sub-woofer to Pioneer VSX-453 surround...
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
Connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
0 characters
3 Points
I want to connect kenwood woofer sw-07 to pioneer amplifier vsx-d859tx. i am unable to connect please guide me.
I don't recall correctly if your Pioneer has a sub out RCA connector, and if the Kenwood SW-07 has a low level input. So the usual way is to connect it using the speaker wires.
You connect either the FL or the FR to the sub and it should work.
Good luck
Jan 11, 2015 | Pioneer Audio & Video Receivers
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Rear speakers no longer function
Have you run the test tones in surround or ProLogic ??
Feb 03, 2010 | Pioneer Audio & Video Receivers
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
Sub won't work
if using a sub out cable to a powered sub,you have to go into the reciever menu and turn the sub out on
May 17, 2009 | Pioneer VSX-406 Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Apr 08, 2008 | Pioneer VSX-454 Receiver
Audio & Video Receivers Logo
2,146 people viewed this question
Top Pioneer Audio & Video Receivers Experts
Steve Sweetleaf
Steve Sweetleaf
Ron Dufek
Ron Dufek
Are you a Pioneer Audio and Video Receiver Expert? Answer questions, earn points and help others
