Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door goes up about a foot and stops
My garage door travels up a foot then stops. To make it go up all the way I cover the sensor and push the remote again and each time I do this it goes up a foot until it finally is open all the way. It closes normally. If the door is not attached to the traveler the traveler cycles up and down without a problem.
    President:
  • 3,197 Answers
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
Posted on Jun 30, 2009
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have Sears Craftman 1/2 HP garage door open that want stay shut when you push the remote the sensor wire broke fix that. Now the door goes down and come back up. All sensor are led light are green...
Check the sensors again. Our unit has one amber and one green when working and if something (even a weed) breaks the optical beam it reverses and the lights blink. We've also had bright sunlight interrupt the beam. (The test for this issue is to stand such that you cast a shadow onto the sensor without being in the beam and then attempt to close the door with the remote). Next check if the door is binding during travel. If it is, check the tracks for plumb with a level and make sure the door rollers and tracks are undamaged. If a rail is crimped anywhere, it could be cause the problem. You can find some garage door sales places that sell the track sections and rollers to replace damaged parts. Check your local phone book and call around. In some cases, the door jamb may be damaged (lowering the header and shrinking the entire door area). This may require calling a professional to fix.
If the door itself is moving easily, then it sounds like the door might be hitting the floor too lightly or trying to go past the floor and triggering a safety reverse. On most of the openers, there are several adjustments you can work on to reset this. First try adjusting the down limit to above the floor and then bring it back to the floor. (However, usually these do not make the opener light blink.)
Alternatively, adjust the downward force to a higher value.
Without knowing the model of your Craftsman opener, I'll just use the directions for mine. All of these are adjusted with a flat blade screwdriver. Always test each adjustment with a complete up and down cycle.
The height limit control is on the side. (It's the forward one of two screws inside the cover - you should be able to reach them thtrough holes in the cover. Unfortunately, sometimes it's easier to get to them after removing the cover. The cover is held by 4 screws - 2 on each side.) To decrease the travel, turn the Down screw clockwise. One full turn of the screw is 2" of door travel.
The force controls are on the back with the down adjustment on the right. Turn this clockwise in 10 degree increments and test each time.
It is possible to overheat the opener with too many open and close cycles. In that case stop adjusting the unit and wait 15 minutes for it to cool.
I hope this helps.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door keeps going up randomly. Both remotes are in the car so there are not being pushed..dont know what to do
Try to re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup may be that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Aug 14, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
The door will only travel a few inches and then stop and then goes back up. Or, it will travel to complete close, stop and then goes back up. Any thoughts?
If the main light is flashing 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and that the small light on each one is lit. If you cannot get both lights to come on you have bad sensors.
Oct 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Worked great the past 2 years. Now, garage door
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens 1 foot, then stops.
It sure sounds like you have a broken door spring. While you are at it remove the cover and take a good look at the drive gear. It is white nylon and is just in front of the motor. Might be stripped and unable to take the weight of the door.
Jun 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old garage door will work.
On the back of the opener near where all those white wires go you will find 2 controls. One is labeled "up force." Increase this about 1/4 turn.
May 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
303 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
