Question about Audiovox D1420 Portable DVD Player
Screen reads NO DISC
When I put a disc in my into the player it the screen read loading for about 2 minutes then the screen show NO DISC. You can hear the DVD turning in the DVD player. The DVD DISC does work in other DVD players. Any ideas on what might be wrong?
  • 3 more comments
  • zaysmom Nov 21, 2007
    I'm having the exact same problem. I tried playing a CD, and it works with that. For some reason it can detect CD's, but not the DVD's. We've tried cleaning it, and it didn't help.
  • 99steve Dec 01, 2007
    Screen lights up. Says loading for about 2 minutes and then says "no disc".
  • nyoni Dec 04, 2007
  • Frankygoes Dec 05, 2008
    Hi guys, I have got the same problem. I found one of the cause: the drive seems to be disabled because the disk does not turn. check your unit, notice the location of the disk by putting the text strait. Close it then try to load. The disk should turn, then the lable location will have change. Open the unit, you will notice that the disk did not turn. I opened my unit and I jumped the cd motor drive to check if the motor was good: verdict it is good. For some reason the power does not reach it through the electronic card... I was happy with the unit: good sound, good image, small... I would like to put it back online...
    Any idea on how to make it works
  • megamoo Jan 17, 2009
    I have the exact same problem. White strip does not seem to be stretched. I can hear the motor trying to spin, but the disc does not seem to rotate, so maybe it is internal. Is it coast effecttive to repair or just replace?
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Posted on Feb 16, 2009
SOURCE:
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
SOURCE: Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Posted on Aug 20, 2009
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
jdvillanueva
  • 2098 Answers
SOURCE: when i insert a disc in my dvd player it reads "no
Hi mgarragh1,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
Ifyou already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I would advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 23, 2011
How do I stop the player from trying to load a disc?
if you put one of the clear plastic disc that come with writeable cd's to protect them, place that in the tray you should be good to go.
Jan 08, 2016 | Televison & Video
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
I updated my Sharp AQUOS BD20 with latest firmware recently. It played the disc that told me the player needed firmware update, but now it seems to take about 5 minutes to read a disc - if it reads it. It...
this same thing is happening to me. It took forever to load Toy Story 3 (10 minutes?) and I've been waiting over 15 minutes for Robin Hood to load - I don't think it is going to. Sharp BD-hp20, new firmware.
Aug 20, 2010 | Sharp Televison & Video
When a disc is loaded, it reads no disc, and disc cannot be played.
It is very possible that the lens motor has burnt out. Sometimes the capacitors on the motherborard short out causing the gear timing to go out..
The only thing you can do to fix this is to take the cover off. Get cotton swab and dip it rubbing alcohol and clean the glass laser eye with it.
Jun 03, 2009 | Samsung DVD-HD850 DVD Player
Ps2 slim not reading discs
You can buy new DVD pickups online for about 15-20 It will take a very small phillips screwdriver and needlenose pliers to change out the old one
Mar 22, 2009 | Sony PlayStation 2 Slimline Console
Screen says "no disc" when there is a disc
has it ever spun and do music cd's work cheack the regon number on the dvds and the player
Jan 24, 2009 | TruTech PVS12701 Portable DVD Player
Disc is not being read,not spinning
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 21, 2008 | Televison & Video
Screen reads "No Disc"
The laser distance servo may be faulty and the laser assembly catching on the disc.
Apr 11, 2007 | Pioneer DV-250
Audiovox D1420 Portable DVD Player Logo
565 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
