Question about Garmin nuvi 200W GPS Receiver
Why doesn't my garmin nuvi 200 gps system charge?
  • Garmin Expert
  • 343 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your GPS in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
Posted on Feb 06, 2010
Can not find a USB slot in my Garmin Nuvi 200
I can help you update your Garmin Nuvi 200.
Here is a picture of where the USB cord plugs into your nuvi:
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 21, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Need to find a manual for Garmin nuvi 200 GPS
you can download the manuals free of charge from WWW.garmin.com. Your gps is the 200 series, so the 205 should work as well.
Mar 30, 2010 | Garmin nuvi 200W GPS Receiver
Hellio, my garmin nuvi 200 cant find a satellite,
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 24, 2010 | Garmin nuvi 200W GPS Receiver
Garin nuvi 200 cannot aqcuire sattelite
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 200w while charging the battery it started to flash and went dead. It will not respond.
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I hope that helps.
___________________
Sep 04, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 200 worked fine the first 3 times
Connect your GPS to your computer with the USB cable and this will charge the GPS internal battery. Of course your computer will have to be on during the charging process. After a few hours turn on your GPS and see if it now works. If it now works then go to http://www.garmin.com and register the GPS. While you are on line also download the latest USB drivers for your computer and install them. When you reboot your GPS should be properly connected to the computer for Operating system downloads etc.
Apr 07, 2009 | Garmin nuvi 200W GPS
Id the Garmin Nuvi 200 supposed to function when plugged in?
Are you using the factory supplied Power cord or a standard Sony-type plug?
Mar 01, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
364 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
