Question about Toshiba Satellite A35-S159 Notebook
Laptop bios at the startup screen it says press DEL to enter BIOS setup and by the time i do, the laptop is shut off. it turns on and off by itself in the mean time
    Novelist:
  • 166 Answers
Its power supply have serious problems and plz consult any nice electrician for its power check-up otherwise it will harm ***********-board or RAM which are really costly affair to be played with.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 30, 2009
How to enter bios setup
press esc or press F1 to F2 sometime press DEL you can read it on the startup (black screen which one )
Jan 13, 2014 | Acer Computers & Internet
Press DEL to enter Setup, Press TAB to display BIOS POST message
to install window7 just put dvd in tray startup computer do what it says to do asn question
Jan 25, 2013 | ASUS M2V Motherboard
Ideapad Z560 neither accessing BIOS setup or is starting normally
Your bios seems corrupted. You will probably need to reflash from a thumb drive which is bootable. The F2 should get you to booting screen to access the thumb drive to boot from to flash the bios.
Dec 23, 2012 | Lenovo IdeaPad Z560 Notebook
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
Reset bios laptop ibm thinkpad 2647
Turn the computer off.
Turn the computer on, and immediately look for a message on the screen, e.g.,
press <blah> to enter BIOS SETUP
or
press Enter to interrupt normal startup
Press the specified key. Then, choose to enter BIOS SETUP.
Use the arrow-keys on the keyboard to navigate to 'LOAD BIOS DEFAULTS'.
To reload those settings, just press the Enter key.
Feb 12, 2011 | IBM ThinkPad T20 2647 Notebook
When ever i power up my toshiba satellite laptop,there are two blank screens with a blue box in the centre saying enter password
the bios passowere has been engaged go to bios by pressinfg del or F1 button on startup go to bios setting password you will see enter password press button with passord blank again it will ask for confirm password enter blank password press enter it will delete all the password if you are un able to enter bios and asking for password remove the cover you will see three jumber pins near ur cmos battery pin one and towo are for normal pin 2 and 3 for clear comos in some there are only 2 pin short the pin to clear the cmos some times shorting doest start the computer dont worry put the jumbers back to the normal position and restart the computer while stating you will see cmos reset press F1 to continue or press DEL to enter bios press DEL and enter the correct time as clearing the cmos the time will be set defult if you cant see cmos jumper pin remove the cmos battery and restrt the computer then shut down the computer and place back the cmos battery in its compartment doing this please remove the power to your hard disk or your haRD DISK MAY GET CORROUPTED
Oct 24, 2010 | Computers & Internet
Where can I find info to setup bios. also how do I upgrade bios
For this you need to know the exact model of your motherboard. Your current BIOS firmware version can be seen in the BIOS setup window itself ( Press DEL key during your system startup to enter into BIOS screen)
Your motherboard should have Flash BIOS so as to upgrade its firmware. All latest motherboards will have this type only. Goto your motherboard manufacturer website and search for latest BIOS firmware for your exact model. There itself you can find the utility required for BIOS. download that utility and using which you can update your firmware. Please do update your BIOS only if it is required.
I hopt his is helpful to you
Dec 31, 2009 | Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
Mar 07, 2008 | Dell Latitude D600 Notebook
E-Machine T1100
What kind of BIOS version do you have?? here are some commands for the diverse kind of BIOS.
AMI (American Megatrends, Inc.) BIOS: DEL
Award™ BIOS: CTRL+ALT+ESC
Award BIOS: DEL
DTK® (Datatech Enterprises Co.) BIOS:P ESC
Phoenix™ BIOS: CTRL+ALT+ESC
Phoenix BIOS: CTRL+ALT+S
Phoenix BIOS: CTRL+ALT+INS
Feb 15, 2008 | E-Machines eMachines Desktop PC
Toshiba Satellite A35-S159 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
