Question about Ovens
The oven door came off, really having difficulties putting it back on
  • 157 Answers
Make hinges normally lock in a postion put the door in then release hinges
Posted on Jun 30, 2009
How do you clean the oven door between the glass.
with great difficulty!! door has to be removed from the oven then on a flat surface remove the screws around the edges then lift the top half off . clean glass dry really well and replace it in the shell . replace top half of door and retighten the screws . replace on oven .
Mar 15, 2017 | Ovens
Changing door catch
Hello Jim;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number which is located either on the face of your oven after you open the door or on the side of the door.
Depending on the oven model that you have will dictate the difficulty of the task. Some are easy, others are difficult with reassembly.
So, I want you to fine your model number. Go into the following website and put your model number in. You will get diagrams, part numbers and prices.
Record the part number of what you need. Search the internet for best price.
You may just have a bad door switch. Push in the door button. If you here a click the switch is good.
If you have a built-in wall oven, this is another story and get back to me.
Water Filters Lawn Garden Appliance Parts
Apr 05, 2016 | Ovens
Oven door closes but does not fit snugly against the face of body of oven. have taken door out and put back in/on with no joy, owner of oven thinks it has been like this since new.
It is like that on the bottom, of my own door of my oven.
Since new! On the older oven I had, you lifted the door and it's hinges up and out and the door came off to make the old way of cleaning the oven easier - when you put it back on, the door would pull up tight on all sides - new ones' seem to have a gap
Mar 12, 2015 | Ovens
Oven door won't close all the way
I have had that trouble a couple of times. This might work. The door is usually attached to the body by two hinges with arms. You can lift the door off those arms and hinges by opening the door a few inches and lifting the whole door up in the air. Try this GENTLY. If the door acts like it will come off the body, it might be misaligned. Try lifting the door, and putting it back a few times, sort of gently twisting it from side to side. Really be gentle. This has worked for me several times. Be blessed.
May 12, 2013 | Ovens
I purchase the Whirlpool electric double oven range GGE350 almost a year ago. The problem I have is with the oven door. There is evidently spillage or something between the glass pane. How is cleaning...
Hello, Thank You for using FixYa. I will be helping you today.I would recommend paying for a service call to have a tech take the door apart for you. There are four pieces of glass in the door and lots of screws. It really is a pain to take doors apart we as techs get this call all the time. Believe me you will thank me you paid someone to do it. If it were easy i would tell you. Most people take them apart then end up paying because they cant put it back together.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool RBD305PD Electric Double Oven
How does one rmove the oven door of a jenn air oven. I can not find instructions in the owners manual or installation guides/instructions. Do I need to remove the hinges or is there a release mechanism?
Look at the hinge, their is like a slider bar to move or you remove the little cover plate, with the Philips screw..then lift the door up and out while pulling...
I WARN YOU, if you really don't need to remove the door don't, it is very hard to put back on unless you have had practice....
Dec 19, 2010 | Jenn-Air Electric Double Oven
How do i put the oven door back on after i removed it to obtain measurements. now i can not get the door back on
I had the same problem today I found that you have to extend the hindge enough to have the lock tabs lock into the door to hold the hindge in the extend mode. If the tabs are not back in the door it will continue to snap back. After you lay the door in place be sure to extend the lock tabs back up into the oven side towards the pins that you hindge lay on. WATCH YOUR FINGER TIPS!!!
ken@mobilevapor.com
Nov 14, 2010 | Ovens
Oven door won't unlock after cleaning oven2 days ago
Set the oven back to the clean leave for 5mins then switch off. If the door does not open still you may have a problem with the door lock mechanism or the limiter that controls it. Hopefully, just putting on then off will correct a 'clitch' and it's nothing too major. Really hope this helps, best of luck
Aug 23, 2010 | Ovens
I have a Neff U1420 double oven and the hinges on the main oven do not close the door fully. I have read that it is possible to correct this problem by putting washers under the screw of the hinges but I...
Hi.
If the door does not close properly then the fault is a faliure in the door hinge springs. Sorry but using washers will not cure the problem..
The only way is to replace the two door hinges. You may NOT need to replace the hinge backs.
If you would like to email me the full model number (numbers after U1420) then i can source the part numbers for you.
regards
Aardvark Repairs
aardvark.repairs.btinternet.com
Nov 17, 2009 | Ovens
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Ovens Logo
172 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
