Question about Hayward H Series Induced Draft Abg 100,000 Heater
Fan kicks on, hear a click about 10 sec's when the heater should normally kick in. It is blowing air, fan works but no heat. Been using for a month ok, used last three months when new last year
  • 990 Answers
You may just be out of gas or a valve may be off. If not you need to look for a ignition problem. A bad glow plug or no pilot. The fact that your blower works and the click you hear narrowes it down to these two things. Good luck.
Posted on Dec 10, 2009
LG window air unit. Been having trouble with control panel for months, but unit cooled. Now it will light up and fan will blow, but compressor does not kick in. Unit about 4 years old.
Possibly a faulty run capacitor in the control box. This is fairly common to LG. the fan motor and compressor use them to start and run more efficiently and when they fail the fan or compressor either don't start at all or run poorly. You can usually tell if you can hear the compressor 'hum' briefly then stop every 10 - 30 secs. this is the compressor trying to start but unable due to the faulty part. LG often have a dual capacitor (two capacitors in one case) so the fan may stop working also or at least run slower. They are common parts available at most electrical wholesalers although the genuine LG parts are normally dirt cheap. Need a model to check the circuit diagram to be more certain.
Aug 24, 2017 | LG Heating & Cooling
My heat kicks on, I can hear it and feel heat when placing hand on vents. However,Nothing blows out.
Blower is not running ? Or is ?if the blower fans not working check fuses or replace motor , if your heat cycles and your blower blows cool air , its likely a heater core issue
Nov 09, 2015 | 2007 Ford Freestyle Limited
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
I have a honeywell gas heater hanging from the ceiling in my shop Model # uhpa175ae-3 Serial # 6396j03508 The exhaust fan starts, the flame lights and finally the main fan kicks in. Quite often, as soon...
HI clean the flame sensor check out the pressure switch jump this out to see if it lights clean sensor on fan control might be dirty clean heater with air line burners heat exchanger then it might be your limit switch but this help doing this other work first
Feb 01, 2010 | Heating & Cooling
HEater is heating outside but not blowing warm air thru the vents inside the house. May blow air for 10 mins but then stops. I have the temp. set at 76 degrees but it is 48 degrees in my house right now.
sounds like you may have some restriction in the heater or overtemp sensor is kicking out to soon, clean everything thourghly, check fan and oil bearing, check safety circuits in furnace wiring, refer to owners manual trouble shooting guide
Jan 30, 2010 | Goodman GMS90703BXA Heater
I have a AquaCal Heatwave H125C-A Pool Heater. The Heater is working in that the power is going on and the air is blowing- although- the air is usually colder than the outside air and now it is only air...
Sounds like your compressor is not running. After your fan goes on in one to five minutes you should hear the compressor kick in. If it does this and then kicks out again it can be something as simple as water flow and you can adjust the valves to get more or less flow to keep it running. If not you probally need a repairman. It is ether your compressor or the capicators that start the compressor and this is all high voltage. Good luck.
Jan 25, 2010 | Aquacal HEAT PUMP 120,000 BTU H135 -
1998 Rockwood Tent Trailer
check connections -test and check ignition ,gas valve ,thermocouple for proper placement ,dirty or damaged
May 03, 2017 | Heating & Cooling
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Wheel fan would not kick on after electronic heater starts to blow air in ducts although the fan is tested in working condition
Did you recently replace the thermostat? If so you need a thermostat for electric heat. This thermostat will turn the blower on when the heat is calling.
Jan 25, 2008 | Heating & Cooling
Hayward H Series Induced Draft Abg 100,000 Heater Logo
291 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
