Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Elite Can anyone tell me why I am getting 120v on the neutral side on the light and auger motor.  There should only be 120 when light is on and the motor running.  This is what I believe is keeping the light and motor from operating.
  • 288 Answers
You will get a 120v reading on the common side if the neutrals connect to another component that is running and you check to ground. Check the wiring diagram, all the common connect together at some point.
Posted on Nov 13, 2007
Dispenser door opens, but auger motor doesn't operate for cubes or crushed ice.
I believe that voltage to the auger motor should be DC voltage. Yes it could be a relay on the board causing this and it could also be the Auger Motor 2252130
Dec 06, 2015 | Refrigerators
Kenmore elite 106.5770 ice auger motor is out. Flaps move, microswitch seems fine. Ice bucket already pulled and cleared. Ice maker works fine. Still no action from auger do I get at it? ...
This is probably one of the best videos I have ever found on replacing auger least how to access them in Kenmore units. I hope this helps you with your issue.
Nov 28, 2017 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How do I wire an intermatic t-103 timer switch
The T-103 has a 120Volt clock motor
From there, the wiring can go two directions depending on your Load voltage (load is the fan, light or motor that timer turns on-off)
Here is a link that shows exact wiring:
When wiring the T-103, steps 1-2-3 are true for 120V or 240V installation:
1) A white Neutral wire is always connected to terminal A (Neutral wire connects to Neutral busbar in breaker box)
2) A black Hot wire is always connected to terminal 1 >> this hot wire can come from 120V or 240V breaker
3) Black wire going to Load (fan, light, motor) is always connected to terminal 2
The following step is true for 120V Load
4) if Load is 120V, then white wire from Load connects to terminal A
The following steps are true for 240V Load
5) Only the neutral wire connects to terminal A as described in (1
6) The second Black hot from breaker box (240V has 2 hot wires) connects to terminal 3
7) The second White going to Load connects to terminal 4
Here are 2 more links that show how 120V and 240V circuits are wired
Oct 21, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Kenmore ice dispenser not working on side by side 2000 model
If you take the ice bin out and gain access to the motor by removing the cover over the motor area you can check for voltage to the motor when you try the dispenser switch. If it's not getting voltage the switch is bad. If it gets voltage but don't turn or if it bogs down easily the the motor is bad.
Sep 22, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Motor went out on kenmore ice dispenser. how do I change it.
need new auger motor remove ice bucket and ice maker remove back panel remove auger motor and replace put it all back in reverse.
Aug 17, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker auger
To see how the auger goes back together, go the the Sears parts web site and put in your model number. It will show the parts list and a diagram. You may be able to print it out, Don't remember if there is a print option or not but if you have a screen capture program you could also.
Apr 13, 2008 | Whirlpool EL7ATRR Refrigerator
Ice Dispenser motor/Dispenser light
I assume that the problem is that the ice dispenser is not working. If you have put 120v onto the auger motor and it won't go, then obviously the motor is faulty. Reconnect the motor to the wiring harness and put your tester on the white & blue wires. Push the door switch so the fridge thinks that the door is closed and push the ice dispensing lever. If you get 120V to the motor and it won't go, replace the auger motor.
Nov 01, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser
problem sounds like its in the board on your freezer door (dispenser)
Oct 31, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
