Question about LG LMV2053 Microwave Oven
Powers but no heat. Everything else functions
Barely on its second year and no heat on any setting. LG won't look at it without receipt so ??? Magnatron(sic?) warrantied for 7 years. any thoughts?
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Jul 01, 2009
My 24lit. LG MG-583MC multiwave microwave with grill very slow to cook i.e. A cup of cold coffee takes about 2,5 min to boiling point.
sounds like its not on high power.. Some microwaves have a popcorn button..This is usually automatically a high setting.Try putting your water in then hit popcorn...If the water heats up faster then your power settings are set wrong. You just need to change them. Your not set on high power..
Jan 12, 2018 | LG Microwave Ovens
JEM 31 is not heating
Sounds like you have a bad transformer. Magnatron should check less than 1 ohm (with wires unplugged). Diode should check resistance one way and open the other. Must have a proper diode checker for this. Check resistance on the capacitor (make sure it is discharged first). Resistance should come up then back to open, reverse and same thing if cap. is good. Check resistance on transformer windings.
Nov 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating
May be cheaper to replace than repair--Likely if has a turntable and it does work that the inverter (power) or the Magnatron is bad.
Each of those parts can cost over 100 dollars not counting labor.
If table does not move it may be another less expensive issue.
Jun 17, 2012 | LG Microwave Ovens
HVM1750 won't heat
The magnatron is likely to be the problem... though I have seen the fuses go , they usually follow the magnatron.
If your unit is under 5 years old , the Mag is covered under warranty and all you need to do is contact GE at
gechsconsumerrelations@ge.com
with the serial number of your unit and they will send you the replacement magnetron imediately and free of charge.
You are responsable to have the part installed , but there are videos on Utube that will walk you thru it no problem.
Sep 30, 2011 | GE HVM1750DMBB / HVM1750DMWW 1000 Watts...
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Power works, everything seems normal but no heat
microwave ovens do not produce heat, they produce microwaves. the heat comes from whatever is excited by the microwaves. In your case i would bet that the magnatron (microwave tube) has become defective. If this oven is less than 5 years old, the magnatron may be under warranty. depending on the model it may be repaired at no cost to you. In the case of Kenmore (Sears) you would take the oven to their customer service dept and they will send it in for you for evauation. they will charge you $50.00 US this amount will be applied to the repair if you choose to have it fixed. If the Magnatron is bad and is under warranty, they will fix it, and return it to you along with a refund of you $50.00.
Mar 22, 2011 | RCA Microwave Ovens
It will turn on but will not heat
Sounds like the magnatron is shot. This is the main heart of the oven, the magnetron is what creats the Micro waves to heat the food. You might want to find out what it cost to get this replaced and then decide wheter the cost of fixing yours is greater than replacment of the oven. Christmas time is here and Microwave ovens are usually cheaper this time of year. This unit might have a fuse to the magnatron, you can remove the cover after you UNPLUG the machine and see if there are any replaceble fuses inside the cabinet. If this has any years and lots of use on it, I would simply repalce it. You get a warranty with a new oven and someplaces let you choice a replacement type warranty.
Nov 15, 2010 | General Electric Microwave Oven
GE JVM1440BD Won't Heat
If it making a louder than normal humming or grunting sound when operating, than it's a sure bet it's the MAG.
Jun 09, 2008 | Microwave Ovens
GE JVM1650
The owner's manual will give you the warranty length. If you don't have yours, you can find it here: http://www.geappliances.com/shop/prts/
You really need to call GE on this. Only they can answer if they will still cover it. GE Answer Center -800-626-2005, 24 hours a day, 365 days a year.
Otherwise, it may fall under your State's lemon laws. You can contact the Attorney General's office, usually via http://www.state.xx.us (where xx is your State's 2-letter abbreviation).
Nov 04, 2007 | GE JVM1650 1000 Watts Microwave Oven
LG LMV2053 Microwave Oven Logo
388 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
