Question about Crunch Car Audio & Video
Pertect ligth on - Crunch Car Audio & Video
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
Whats the best pertection on a malware tablet android
Norton is good if u have a computer with Norton its free in youre phone or tablet cheers
Aug 20, 2015 | Craig Touch Screen Android Tablet 7" Model...
Turn radio on it just flashes pertected
There's a short somewhere between the unit and the speakers.
Sep 25, 2013 | Kenwood KDC108
Do I HAVE A VIROUS PERTECTION ON MY COMPUTER
Virus protection programs are not installed on new computers. Most like you are not protected.
I suggest you install one of these free virus programs.
Microsoft Security Essentials
http://www.microsoft.com/download/en/details.aspx?id=5201
AVGFree
http://free.avg.com/us-en/download-free-antivirus
May 08, 2013 | Dell Computers & Internet
Canon rebel xs say card write pertect
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 30, 2011 | Canon Cameras
When i turn the amp on the green light comes on for about 5 sec then the red light comes on for pertection mode
disconnect speakers and cycle the power if the same thing happens the amp is bad!
Feb 23, 2011 | Pyle Car Audio & Video
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
I HAVE 2 AUTOTEK MEAN MACHINES MODEL 66 AND THEY GO INTO PERTECT
Contact Eric @ Capital Audio & Electronics repair in Tallahassee FL we trepair all brands & models 850-339-1130
Mar 06, 2010 | Autotek Car Audio & Video
Cannot find location of the spade fuse
I have an older pmp1200 and NO, you don't have to take the back off. Those spade fuses are for an empty RV power buse position where you will connect the inverter to fuse the DC side. The PMP 1200 has pertection circuts inside for overload, but if a short on DC input were to occure it would not pertect your buse (and of course the battery) from causing a posible fire situation. Since the DC cable size needed for the maximum curent draw on this unit is so large (4 gage), I would recomend a direct battery conection fused via a fuse holder that can handele the max current (10 amps). Check with your local battery stores for such items. Warning: don't use fusing over this 10 amp rating because if the unit happens to short, it could start the battery to over heat and cause a fire or battery explosion.
Jan 29, 2009 | Coleman Cable Power Inverter PMP1200
Car Audio & Video Logo
259 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Vernon Taylor
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
