Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Why does my magic chef refrigerator leak water on the floor
  • 2,418 Answers
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Posted on Jun 30, 2009
  • 56 Answers
SOURCE: 10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
SOURCE: SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Posted on Mar 13, 2008
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: Magic Chef CTB1722 refrigerator leaking water from
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
  • 72 Answers
SOURCE: we have a ice maker and water dispenser on our
I see a lot of cracked lines and cracked inlet valves take back off turn water on and find leak dont be scared just unplug it 1st any questions we are here for you Allbrand appliance lou,ky
Posted on Jan 29, 2010
Water appears on the floor outside the fridge. I have a side by side fridge freezer, Magic Chef
There's a tray under the refrigerator that catches the water dripping down when your auto-defrost cycle runs. Usually this water evaporates before the tray overfills. Either you don't have enough air flow around the refrigerator for the water to evaporate, or the tray may have developed a leak.
Oct 10, 2014 | Refrigerators
I have a magic chef French door refrigerator. Water under the freezer becomes ice and when this melts water seeps onto the floor. Sometimes enough water to completely soak a couple of towels
Lower the setting to your FREEZER this may be defrosting too often and the drip pan is over filling, or stop leaving the doors open too long .
Oct 04, 2014 | Magic Chef Refrigerators
Hello we have a magic chef refmodelctf1826arq which started to leak water onto the floor from underneath I can not find the reason why leaking ref is cold, and ice maker working.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Magic Chef Refrigerators
Water pooling under the vegetable bins on the refrigerator floor enough to fill up the cavity and leak out the door onto the kitchen floor. It is Magic Chef CTB1925DR. We have to constantly pull the...
Leo Ponder
imufo2
Aug 30, 2011 | Magic Chef CTB1821AR Top Freezer...
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Magic Chef Refrigerators
I found a water pool on the floor...
a coupltle thinges ,ur het plate to evaporate condensation it out, ur low on collant, or door sel is not sealing
May 30, 2010 | Magic Chef CTB2125 Top Freezer...
Feb 17, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
1,526 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
