Question about Panasonic PT-51HX41 51" Rear Projection Television
Double shadows We had a lightning storm about 1 month ago & I have to replace all of the outside/inside cable boxes, network card in pc and now my projection TV is showing double at the bottom of the screen after it warms up for about 5 minutes.
  • b87jTX Nov 08, 2007
    I guess I should have told you my Projection TV is a Panasonic PT-51HX41....tks..
  • 375 Answers
Requires a service call to be realigned ,your convergence ic's have lost their settings from the eeprom ic(memory),look in your menu settings to see if you have auto-focus if there activate it and if the ic;s are still ok it should fix it.
Posted on Nov 16, 2007
Lightning Storm messed up one HDMI Input
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 09, 2017 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
Inside my emachine desktop pc where do I find the network interface card? I need to replace it since an electrical storm destroyed it.
The NIC (network interface card) resembles a telephone jack only larger. It's where your ethernet cable goes. On some E-machines, the NIC is onboard meaning it's permanently attached to the motherboard. If this is the case, it's still possible to install a different NIC in 1 of the blank PCI slots. Remember to Disable the existing NIC in your device manager to avoid any possible conflict.
Aug 31, 2011 | E-Machines eMachines Desktop PC
Lightning in area. Cable issues ---resolved. Laptop wireless working fine. Desktop internet won't connect. Attempted restore. No go.
Most likely the power surge generated by the lighting has fried the network chip - you will have to replace the wireless card in the desktop. You can easily check for that by booting from a Linux Live-cd and try to use it in there.
May 26, 2011 | Sony VAIO PCV-RZ16G (T99861082) PC Desktop
Why using a telephone during a lightning strom is dangerous?
Lightning routinely gets into copper telephone cables during storms and can overwhelm the fusing protectors at your home and enter a telephone set, causing a lot of immediate damage to the telephone and the user.
Lightning can travel from outside your home to inside your home—and to you—through materials that conduct electricity, including electrical wiring, phone lines, water, and plumbing. These safety guidelines will help minimize your risk.
If you need to use the phone corded phones are dangerous during thunderstorms. Lightning traveling through the telephone wires has killed people. Cell phone and cordless phones are a safer choice, but stand away from the cell or cordless phone's power base
Hope this will help you.
Mar 18, 2010 | Lands Phones
Jensen TS2750J
my tv did the same thing about one month after i bought it luckily it was still under warranty it turned out that when i had a lightning storm it shorted some fuse inside the part was $100 i tried to replace it myself but it needed a specail tool. good luck
Dec 19, 2008 | Jensen TS2750J TV
We had a lightning storm and now the ac wont work
Depending on where you live, there are electrical codes that require a 'disconnect' near the outside unit.. This is to be removed prior to servicing that unit and prevent the service person from getting injured if someone inadvertantly turned it on The humming sound you may be hearing may be the fan motor insise that unit, It is possible that the lightning strike generated a surge that damaged that fan motor winding.. With the protective screen removed and that unit disconnected from power.. try spinning the fan by hand to make sure it is free to turn, then reassemble everything and see if will start up. If it is a 220VAC system then you could also be missing one phase of power..You might want to contract an electrician for that aspect of troubleshooting. Be careful and goodluck..
Aug 22, 2008 | Goodman CKL30AR30 Air Conditioner
D-Link DFE-530TX+ installing on our desktop
That cable could be the wake-on-LAN cable, it is used for the connection of the card to the motherboard's wake-on-LAN slot, this is only used if your motherboard supports wake-on-LAN and you want to open your pc remotely from another location. But if don't need remote pc connection you don't need to install this cable.
Jun 16, 2008 | Televison & Video
Lan card disabled
When u plug the ethernet CAT cable in the LAN card socket , so you see any light orange or green flashing on the LAN card itself.
If yes then right click on my computer >> properties >> Hardware >> device manager>> check in network adapters whether the LAN card is enabled or not
If NO the right click on it and enable it check whether it is able to receive any ip address
If u see no light at all
Then you might have to install a new LAN card on the system
Jun 07, 2008 | 3Com Megahertz 10/100 with XJACK Connector
Panasonic PT-51HX41 51" Rear Projection Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
