Home | Sony | KDF-E55A20 55 in. LCD Television | Bad "GM Boa...
Sony KDF-E55A20 55 in. LCD Television
Problem for Sony KDF-E55A20 55 in. LCD Television
Bad "GM Board" - power light flashes 6 times
By marksails on Jun 30, 2009
2 and 1/5 years old and it just shut down - from a call to Sony they indicated it was probably a GM board" - (power light blinks 6 times) -any thoughts or suggestions - thanks
Comments:
Jul 02, 2009
- Actually no - I have a separate indicator for the lamp - turns out it was that thermo coupler issue. apparently the first few model years this is located under the lamp and over heats - the replacement is routed differently. Fortunately I was able to get it fixed really cheap - its only a 8.95 part (retail) and a friend knew what he was doing
Solution #1
posted on Jul 02, 2009
Not Rated)
1hash
Rank: Wiz  Sony Expert
Rating: 83%, 73 votes
you have a bad lamp.that will cause the same problem
Was this helpful?
Yes
No
Popular Solutions for Sony KDF-E55A20 55 in. LCD
Questions and Unsolved Problems for Sony KDF-E55A20 55 in. LCD
Do you recommend Sony KDF-E55A20 55 in. LCD Television?
Answer
Answer
I have a year old 52" Philips LCD 1080P tv. In the past month the tv will intermittently go... (More)
Answer
T.V. turns on and off every minute but no indicator lights come on.
Answer
does anyone have a copy of the service manual for a sony kdf-e55a20 ?, i only need the pages... (More)
Answer
picture comes in for a few seconds and then back off
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KDF-E55A20 55 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
