Question about RCA HD52W151 52" Rear Projection HDTV
The screen is cutting peoples heads off.
I have tried to change the screen format to normal instead of cinema. I know that it is something simple but I can't figure this out. Please help
If you have the RCA remote there are a circular band of buttons with arrows pointing North, South, East and West. Or up, down and left and right. On the right side ( pointing East) it should say zoom. Click on the opposite arrow (west). This should change your aspect ratio to 4:3. This will have borders on the outside but it is the usual ratio for most channels.
I hope you have the remote because that is the only place I have discovered this feature so far. Forget about cinema and normal, that has more to do with the contrast of the image.
Posted on Jan 28, 2009
  • 1,694 Answers
Called aspect ratio or ? depends on Mfr. brand................
When I go into my customers home unfamiliar with their equipment and no owners manual available, I go thru each menu
selection and check each button on the original remote.......T.
Posted on Nov 08, 2007
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I have a Dynex TV and Dish Network receiver. Last year the TV worked fine, I don't think I changed anything, but this year the top of the screen is cut off when I watch NFL games. The top of the score...
You will need to press the "Format" button on your DISH remote This button will have a * on it. By pressing this button repeatedly, you can change the format of the screen set it to normal. Next grab the factory remote for your TV and try the different formats most likely normal will work best on this setting as well.
Daniel Busa
DISH Network
Customer Service
Aug 27, 2011 | Dynex DX-LCD37 TV
The Picture cut peoples heads off how do i fix it
You can go into the menu display format.
TV have several formats to display 9:16 3:4 Cinema zoom etc
Try the one that works for you.
Many tvs have this button on the remote so try that first.
Feb 13, 2011 | Vizio L32 32 in. LCD HDTV
Cuts peoples heads off, doesnt autoformat
uncheck format , format manually. use "full" or "panorama" setting
Jan 02, 2010 | RCA HD52W59 HDTV Projection Television
Images on the screen are too large -- can't get back to normal
the problem is the setting of record it again, but you need to set the, for wide screen 16:9.choose the most suitable screen format for you.but, just to be sure,choose letter box or LB.
you can find the setting in the menu or set-up
May 15, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
My tv zooms in and changes the format.
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
RCA HD52W151 52" Rear Projection HDTV Logo
136 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
