Question about Hayward H Series Millivolt 250,000 Btu Pool Heater H2501
Can't get supply and return back on heater
Detached the water in and out to the heater to replace apart, now i can't screw the large gray nuts back on to the heater? Tried for hours and only got one on?
  • 139 Answers
Hayward unions are the hardest in the business to get back on.difficulty varies from htr to htr.Try the two person approach,have one hold line level while other attempts to thread on.no real trick just persistence.
Posted on Jul 12, 2009
I had same issue. I wrapped the male haalf with teflon tapa and it slid right on.
Posted on Aug 31, 2009
Trying to replace the passenger side blend door actuator switch.
There should be 3 screws around each adjuster that you remove to be able to remove the heater control from the heater box then swap wiring and install new switch back on to the heater box.
Apr 17, 2015 | 1997 Chrysler Town & Country
Removing water pump clutch
You need to rent/borrow a fan clutch wrench remover set. They are large skinny wrenches that hold the bolts on the fan so it doesn't spin, while loosening that large nut. Sometimes you can monkey around with strap wrenches and crecent wrenches, but thats no fun. Kragen/Oriely's rents the tool for a $89 deposite. Return when done, and you claim back all your money. Yay! free toolls.
Oct 08, 2012 | 2000 Buick LeSabre
I have a rheem heater M/N 81V40D how do I change the anode?
Unless you see a large hex head socket to remove on the top of the water heater, many
anode rods are built onto the hot side nipple. They are almost the length of the water heater.
Hopefully you have room to remove it if this is the case. If you see a hex nut that is silver
gray on top, then shut off cold water to the heater. Release some hot water at a tap to relieve
pressure on the tank or drain some out at the bottom which is better. Make sure power is
off to unit first or gas is off . Unscrew nut or nipple counterclockwise to remove. Best to
remove with a socket wrench or box wrench if it's a nut and a good pipe wrench if it's
on the nipple. Several light taps with a hammer if necessary on the handle of the
wrench or pipe wrench should help. Hopefully the nipple has a removable flex line if
it's located there. (Remember it's on the hot side and should be marked on the top
of the heater).
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to replace heater core for Ford Taurus 2000
Heater and Evaporator Core Housing Removal & Installation To Remove:
  1. Recover the refrigerant.
  2. Remove the instrument panel.
  3. Remove the right side cowl vent screen.
  4. Remove the screws and the water shield.
  5. Disconnect the vacuum supply hose.
  6. Clamp off and disconnect the heater hoses at the firewall.
  7. Disconnect the evaporator outlet spring lock coupling. Discard the O-rings.
  8. Remove the two condenser-to-evaporator line bracket bolts.
  9. Disconnect the evaporator inlet spring lock coupling. Discard the O-rings.
  10. Remove the three nuts at the dash panel.
  11. Remove the screws and the heater outlet floor duct.
  12. Remove the evaporator core housing bolt and nut.
  13. Remove the heater and evaporator core housing.
Heater and evaporator core housing removal/installation ford-10-00-404.gif
To Install:
  1. Install the heater and evaporator core housing in the vehicle. Secure the mounting nut and bolt.
  2. Install the heater outlet floor duct. Secure with the mounting screws.
  3. Install the three mounting nuts to the dash panel. Tighten to 53 in-lb (6 Nm).
  4. Install new refrigerant system O-ring seals lubricated in clean mineral oil. Connect the evaporator lines.
  5. Install the two condenser-to-evaporator line bracket bolts. Tighten to 80 in-lb (9 Nm).
  6. Connect the hoses to the heater core connections. Lubricate the coolant hoses with plain water only, if needed.
  7. Connect the vacuum supply hose.
  8. Install the screws and the water shield.
  9. Install the right side cowl vent screen.
  10. Install the instrument panel.
  11. Lubricate the refrigerant system with the correct amount of clean PAG oil.
  12. Evacuate, leak test and charge the A/C system.
  13. Add coolant as needed.
Jan 08, 2011 | 2000 Ford Taurus
Haw do i hook up the wires corectly for a hot water heater
I am assuming this is a large 240 volt water heater and you are asking about the connection at the water heater. First thing is to turn the power to the water heater off at the service panel of disconnect if it has one. You will see three wires that connect to the heater. Normally a white, black, and a ground that is usually green or just a copper wire. On the water heater when you remove the plate on top you will have 2 wires. A red & black or a white & black. You will see a ground screw. Connect the green or copper ground wire to that screw. The 2 wires left you connect either one to either wire. Makes no difference as each wire is carrying 120 volts. When you connect these wires secure them tightly with a wire nut, no wire exposed, and then, with electrical tape, tape them up so as the wire nut cannot come off. Push the wires back into the hole an secure the cover on top.
Jan 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I just installed a 37.5 Imp Gallon Rheeme Electric Hot water tank, and after installation, the tank was leaking through the top element. after talking with a Rheeme customer support, they will supply the...
First of all disconnect the power at breaker panel or there should be a dedicated shut-off switch if this is a newer building. At any rate make sure its disconnected before you drain the water heater if power is on when the element is not safely submirged in water it will melt instantly. You can do this with a circuit tester after removing the access panel for the element. Turn off the water at the valve above your heater or at main and drain down below the eelement. Disconnect the wires attached to the element and remove element. This can be difficult without the right tool. The element just screws into the tank by way of a large thin nut welded around the element. You have to get a wrench or maybe channel locks or preferably a large deep socket on this nut and turn it counter-clockwise if your lucky this will work. But because the nut is so thin and in a tight area you might need to get an "element wrench" at home depot or where ever. There are different sizes measure your element first. Its basically just a deep socket made out of cheap steel with a hex outer shape so you can put it over the element nut and use a wrench or pliers.
Put your new elemeent in re-connect the wires, remember where they were connected when you take the element out.
Fill the water heater turn on power and replace cover.
I would also suggest try to tighten the existing elemnt first. If the leak is at the seal and not the element itself then the seal may be at fault and not the element.
Check your warranty, if this is less than a year old you should have unlimited warranty including labor. But I know that rheem simply does't have warranty contracts in place with repair techs in some areas.
If your warranty is unlimited (includes labor) and efective then hold them to it.
Oct 28, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Instead of printing consistently, the ribbon backs up. How do I get it to stop backfeeding
Sounds like the either the ribbon supply or ribbon take-up pressure needs to be adjusted.
Supply Spindle: a pair of set screws near the outermost point on the spindle locks the adjustment in place. Loosen the set screws, then move the center pin in or out to change the spindle pressure. Tighten the set screws then test print
Takeup Spindle: a pair of set screws locks the large adjustment nut in place. Loosen the set screws, then tighten or loosen the large nut, tighten the set screws and test print.
Sep 25, 2009 | Zebra 105Se Thermal Printer
Want to find heater hose diagram
please rate. thanks.
Heater Water Hoses
Item Part Number Description 1 N610956-S56 Screw 2 18472 Heater Water Hose, Supply 3 18472 Heater Water Hose, Return A — Tighten to 7-9 Nm (62-79 Lb-In)
Sep 18, 2009 | 1996 Ford Windstar
Trouble installing replcement gasket in Solis Crema SL 70
SL 70/90 Brew Head Gasket Replacement Time 1 to 2 hrs Tools # 2 allen wrench # 1 Phillips screw driver # 2 Phillips screw driver # 13mm wrench First unplug the machine. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 allen screw. Loosen this screw and the rotate the steam knob clockwise until it is removed. Now remove the clip on the steam manifold that holds the steam wand. There may be a plastic tie that is securing the clip. Cut it. Pull out the steam wand and let it rest on the bottom cover. Next remove the 4 large screws that hold the cover plate around the brew head. This will allow the cover plate to drop down and swivel on the steam wand, exposing the nuts that hold the boiler on the bottom metal plate. The nuts that hold the boiler on are # 8. Before you loosen the nuts you need to remove the water inlet nut on the side of the boiler. It is a #13 wrench. Remove the water line. Now remove the nuts that hold the boiler on.
Jun 16, 2009 | Solis Crema SL-70 Espresso Machine
My danze D455612 is leaking and i think it might be an o ring problem. How do i pull it apart. I have taken off the top part but i am up to go any further
I have never taken apart that model before but they are all relatively similar.
The first step is to close the water supply.
Remove the handle.
Either a set screw or nut around the valve stem (packing nut) will be holding the cartride in place.
Once the valve stem/cartridge has been removed then all of the o-rings are evident....replace all of them and the large flat washer at the end of the stem (if there is one0.
Apr 11, 2009 | Danze Plumbing
Hayward H Series Millivolt 250,000 Btu Pool Heater  H2501 Logo
94 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
