Question about RCA L32HD32D 32 in. LCD HDTV
Picture when TV first comes on then screen goes blank.......
When I turn on my tv it works perfectly normal, give it about 5-10 seconds and the screen goes blank - the audio is fine and continues to play even after the screen goes blank. When it first started to mess up, I had been watching the tv for a couple of hours, lines came in the screen and a few minutes later the screen went blank, I can turn it off and back on the picture is there for a few seconds then goes blank.
  • RCA Master
  • 10,291 Answers
TV Parts Universal TV Stands DLP Chips ShopJimmy Your T-Con board is toast. You can get another from here.
Posted on Aug 16, 2017
Axle80
  • 73 Answers
SOURCE: Element electronics LCD, was on for several hours
Typically this failure is due to the backlight inverter going out. On this model of tv there were two runs with different parts. Open the back of the tv and open the control box. If you see a large black circuit board on the top, replace that one. If its tan then you need to take out the control box and remove the black plastic backing. If you're looking at the back of the tv the inverter will be on the left side of the control box. Its a long skinny board that has 8 black metal squares on it. Good luck and be careful.
Posted on Mar 21, 2010
  • 8457 Answers
SOURCE: screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 14, 2010
  • 8457 Answers
SOURCE: TV displays pixels of colors after 2 minutes then blank pink/red
The Tuner board,that the board where ur incomming broscast signal wire is plug into this board.This board is defective,replaced this Tuner board in the tv,than it should work as before.Tries websites like Shopjimmmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Jun 18, 2010
budmrtn
  • 11361 Answers
SOURCE: when the tv comes on picture comes on for a few
You may have failing 24vdc power supply or dying backlight inverter board, you need to check the 24vdc after the screen black out, or look at the sreen in the darkened room to see any glow from the screen, which in that case the problem can be in the T-CON or the main logic board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 30, 2010
  • 608 Answers
SOURCE: Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Sony Blu Ray S350 plays well but have intermittent loss of video signal. Screen shows coloured background (yellow or white), audio continues to play then screen goes black then picture returns; this cycle...
It may be a problem in the digital section of the TV. If you find a part of the movie that blanks out, try rewinding back to it and see if it goes out again. It may also be the HDMI cable you are using. The blank out is often the result of the TV trying to adjust to the correct resolution for the program being played, and we need to diagnose why it is changing resolutions. Microwave interference and voltage fluctuations can also cause these issues.
Feb 25, 2011 | Sony BDP-S350 Blu-Ray Player
When i turn my snes on, the tv screen shows scrambled pictures of the game for a second and then goes black but the audio works just fine. the music continues playing. ive tried three different cords....
Well try cleaning the game packs out with qutips and rubbing alchoal it sounds lIke a glitch then that can occure sometimes with the old consoles
Nov 23, 2010 | Nintendo Super NES Console
My Sony kp-53xbr35 Rear Projection TV screen turns green for a few seconds when I turn it on, then goes blank. Audio still works. Timer/Stand-by blinks until screen goes green, then stops, even when screen...
check the lamp out if the lamp go to this website http://www.discount-merchant.com or if the lamp is not the issue maybe can be the board in the same page you can find the parts that you maybe would nedd
regards
Dec 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
RCA L32HD32D 32 in. LCD HDTV Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
