Question about Dell Inspiron 1300 Notebook
I get a "virtual memory is low" error message. How do I correct
When I purchased the pc desktop it had an older version of windows. I installed windows xp. when I turn on the pc it shows 2 incidents of xp. I think I installed it twice. How do I get rid of it and would that use or cause the error message "virtual memory is low". just before it knocks me off?
  • paralegal54 Jun 30, 2009
    to clarify the advice so well needed and was given. I need to backup all documents then reinstall windows? what about programs will i need to re-install them as well?
    Novelist:
  • 166 Answers
You have two different & independent problems. I will solve them one by one.
First of all, for increasing VIRTUAL MEMORY you should Right Click on "MY COMPUTER" then choose "Properties", then goto "Advanced" tab and then in "Performance" frame click "Settings" and then again goto "Advanced" tab and there you will see a "Virtual Memory" frame and then click on "Set" and increase the size of your virtual memory.
Second problem is due to installing many instances of XP. You can re-format your whole drive again and you will enjoy a fresh & single copy of XP again.
if you finds any difficulty or any doubt is there then feel free to contact me again.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 30, 2009
  • Dell Master
  • 2,404 Answers
Virtual memory is low because you have alot of programs loading in the background. Your best course of action is to try to get into windows and save any important documents and pics you need.
then go ahead and with your operating system cd, boot up off of the cd and when you get to the part where it asks you where you want to install windows, go ahead and delete the partitions.
There will be only one partition at that point. Go ahead and chooose the partition and let windows install at that point. After the installation is done then you won't have to choose which version of XP cause there will be the only one. Also make sure you have your utilities and drivers cd for installing your hardware as well.
Let me know how it goes and I'll help you even further.
  • Ben Wabnick
    Ben Wabnick Jun 30, 2009
    You'll have to reinstall your programs to as well.
Cant fix error
this sounds like a HDD problem, your best is to download a live operating system such as knoppix and boot to it, once in check that you can see the HDD it will be shown as "sda1" gather all data and information you want to keep and reinstall your OS
if you are using windows and you havnt made a recovery disk, then you can either contact the manufacturer to send one out or buy the windows install disk
Jan 06, 2014 | HP DX2000 PC Desktop
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
I recently purchased a new computer (HP/Windows 7) and am having difficulty loading my copy of PDFCreate!3. The error message is: "AddPrintDriver Cause of Failure - 2". Is this version of...
hi,
it does appear that even create 4 didn't have windows 7 support. You may try installing and then changing to windowsxp compatible mode by right clicking the icon and selecting properties and the compatibility tab then place a check in "run this program in compatibility mode" and choose windopws xp. and or install virtual PC with windowsxp compatible then install and run your older software in a virtual machine.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 08, 2011 | Computers & Internet
I trying to play my pc games on my computer but I get an message saying my windows virtual memory is too low. How do I fix this problem?
There are two pretty simple solutions.
1. Close all other open programs before you try to play your game. You don't have enough virtual memory (RAM) to run multiple programs at once.
2. If you receive the same message when only running your game, then you just don't have enough RAM to handle the game. You need to upgrade your ram - verify which type you need and go buy it! It's very easy to install, especially in desktops.
To avoid this in the future, be sure to read the necessary system specs needed to run the game, and be sure you meet or exceed the minimum requirements before purchasing the game.
Jul 06, 2010 | E-Machines eMachines Desktop PC
Presario s6500nx wondows xp error message: " the instruction at 0x75606eb5 referenced memory at 0x0000008 could nnot be read.
If u have installed acrobat then uninstall it.
otherwise download the latest service pack and install it is free on microsoft.com for genuine windows.
increase the virtual memory
mycomputer>right click>advanced tab>performance settings>advanced tab>virtual memory click on change and then make the initial and max size 2500.
restart the machine.
Mar 05, 2009 | Compaq Presario S6500NX (DQ181A#ABA) PC...
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel®...
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Vertiual memory
Virtual memory is really hard disk space used as memory.
If you are running low on virtual memory, make sure your hard disk is not nearly full (check in MyComputer). or adjust Virtual Memory settings:
On Windows XP look in
  • Control Panel
  • System, Advanced,
  • Performance,
  • Settings,
  • Advanced,
  • Virtual Memory.(set to a larger number)
I believe it's in a similar location in other versions of Windows.
Oct 25, 2008 | Gateway Computers & Internet
Dell Inspiron 1300 Notebook Logo
130 people viewed this question
Alun Cox
