Question about Tecnik TKL9260 Front Load Washer
Washer wont drain
I moved my washer away from my wall. took the hose out of the hole in the wall that is inbetween two faucets. i read the forum and it says to drain the hose but how do i drain the hose if it is attached to the washer?
  • santanya Nov 08, 2007
    i moved my washer away from my wall. took the hose out of the hole in
  • shany Nov 25, 2007
    washer won't do a full spin and drain water out. I have checked the filter.
  • 868 Answers
Bring the hose down lower than the water level and it will syphon out................Possibly a clogged water pump :remove the pump hoses and clean out the pump.
Posted on Jun 01, 2008
The black hose that drains the water out has come off and draining water straight out as it fills. I cannot for the life of me figure out where it connects to. Any help would be great!
The black discharge hose (the J shaped one) is connected to the output side of the discharge pump inside the washer. It's likely the hose has come off.
  • first, unplug the washer.
  • Shut off the hot and cold water faucets to the washer.
  • Pull the washer away so you have access to the back.
  • Remove screws holding the back panel in place.
  • Remove panel.
  • Examine the hose where it attaches to the pump. Look for cracks, holes or broken ends.
  • Examine the clamp attaching the hose. Is it broken or worn?
  • Replace any of the above hoses and/or clamps if faulty with hardware comparable with your model. Re-assemble in reverse sequence of dis-assembly.
  • Attach hot/cold water lines.
  • Ensure ALL excess water has been removed before plugging washer in. Ensure ground wire is attached!
  • Plug washer in and start cycle. Examine for leaks.
Feb 01, 2016 | Washing Machines
Wont drain and tries to spin but wont stops flashes an F/ no numbers
Hi Edward:
Does this occur on all cycles? Usually a draining problem stems from an issue with the power supply, the position of the drain hose or a clog in the drain filter.
F variables (other than FH, F02, and SUD) just means a electrical problem.
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer.
Turn off the water supply at the faucets, which are usually recessed in a square compartment in the wall behind the Kenmore Elite washer. Unscrew the inlet hoses that connect the water faucets to the washer. There is a mesh screen inside the hose. Make sure it is not clogged.
Uncurl the water hose if it is wound too many times, restricting water flow. Remove any kinks or bends in the hose that could be blocking water flow.
Re-select cycle and select HOLD TO START. If the problem remains, call for service, because could sound like perhaps the control board go to bad. Unplug it first, let it discharge (usually around 4 min) and then have a go at it again.
I hope that it will help to solve the problem, or will serve as a starting point to initiate a diagnostic work.
Feb 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How to disconnect WD440 Hotpoint Aquarius washing machine?
If you want to completely disconnect it, please do it in this order::
>Make sure that there is no laundry in the machine
>Turn the machine off
>Unplug it from the wall socket and secure the cord to the top of the washer with a piece of duct tape.
> Turn the water off at the faucets that supply the washing machine.
> Loosen each hose and turn it into a bucket or sink to drain it as much as possible.
>Secure it with th4e opening up with duct tape to the side or back of the washer so that you do not drain leftover water all over the floor.
>Finally do the same with your drain hose. You may have to pull the washer out from the wall to do this, but you need to pull the drain hose out of the drain, and bend it to drain to a bucket or sink.
And then secure it to the washer as above with the opening higher than the tub.
> At this point you can move the washer to an area outside or wherever you want to take it. If you are moving it outside, you can disconnect the water hoses and drain them completely and even keep them if they are still good, and you are replacing the washer. You can also remove the drain hose completely if desired.
>Good luck to you. Thank yo for using FixYa. Please rate this solution.
Jan 02, 2011 | Washing Machines
I moved and need to hook up my washer at a new location. I am unsure of what to do with the large hose in back. It is attached to the washer at one end but water is shooting out of the detached end. Where...
Most washer hook up have a drain built into them. Normally the drain is about an inch and a half hole between the two faucets. The hooked end of the big hose just slips down into that hole. If there was a washer there there must also be a drain there at one time. The big hose is where all the water comes out of the washer,
Oct 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer will not drain
Hello there:
I would check the drain pump for a clog. Remove the front panel of the washer, the pump is at the front bottom right side, with 2 hoses attached. Now either get the water out of the tub with a shop vac, or pinch off the hose connecting the tub to the drain pump. Take the top hose off, and stick your finger down the hole and feel for anything. also you can stick a screw driver down the pump and see if the impeller moves freely...
Read more:
Sep 28, 2010 | GE Washing Machines
Water is pouring out the bottom when emptying. What can cause this?
Is you water discharge hose still connected to the drain in the wall? If not, place it in the drain and make sure it is secured and won't pop back out of the drain (tie it down to faucet next to drain). If the hose is connected to the drain, then the hose must have came undone inside the washer, or has a crack in it. Check condition of hose and look inside washer to make sure it is connected.
May 08, 2010 | Maytag SAV2655A Top Load Washer
My washer is keaking water on the front left side. I think when its draining. i had the new style top put on that stops water from spilling on to the floor when filling
check that your drain hose is tight pull machine away from wall and see if it leaks there during drain cycle if it is leaking here tighten connection/Also check that it is tight at the faucets as well
Jan 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Not draining after wash cycle
Did this drain before?
If not, then it may be as simple as a crimped drain hose.
Move the washer away from the wall...
Please comment status...
Sep 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Inglis washer won't agitate
Washer/motor runs but wont agitate or spin...this is often a broken motor coupler. See how to take apart info.
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Apr 01, 2009 | Washing Machines
E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Jun 03, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Tecnik TKL9260 Front Load Washer Logo
50 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
