Question about Goldstar M1003R Air Conditioner
This goldstar air conditioner model is WG2405RY7 It has an energy saver, but the unit just keeps running and won't shut off, everything else works.
    Scholar:
  • 70 Answers
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Posted on Jun 30, 2009
I have a kenmore a/c model number 25378088891 serial number jk80701868 it hase a energy saver on put it is always running and does not shut off is it time for a new one I have hade this for 9 yrs
It is up to you if you want to replace just because the energy saver feature is not working... if it is still cooling then I would probably keep it...but that is your call...
heatman101
Sep 13, 2011 | Kenmore Heating & Cooling
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
Goldstar room ac GWHD6500R
I read that its just simply cool with low fan on energy saver...on another site.
Aug 22, 2008 | LG Goldstar GWHD5000 wall/window Air...
Thermostat ?
I'm thinking the bi-metal is working, that's why you can hear a click, but the contacts are welded together. The bi-metal doesn't have enough strength to break the weld. Time for a new thermostat.
Jul 23, 2008 | Heating & Cooling
Goldstar/air/window unit/runs for awhile and turns off
Does it have energy saver option? Check if you have timer option. If your units runs and then turns off without restarting by itself and you don't have those options call manufacturer or take it back and get your money back.
Jul 20, 2008 | Haier hwr10xc6 Air Conditioner
Goldstar Window A/C Unit Model GWHD5000
I recommend that if you have animal and you want to have the unit on all day that is fine if you have an ac unit with a thermostat and it is big enough to handle.  The unit that is in the window is ok if your home but it could cost alot if there is no thermostat because it will run and run and run.  Then if it don't cool the house enough means its not the right size.  The unit / compressor could overload and kick on and off and might not work when you get home and the house will be like a firecracker.   Best bet would be to replace it with a unit for the size needed for the apartment.  It would be effecient. if we can help further just let us know.
Jul 15, 2008 | LG Goldstar GWHD5000 wall/window Air...
Lg 10000 btu ac wall unit
if you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Aug 05, 2007 | LG Electronic Window Air Conditioner
Goldstar M1003R Air Conditioner Logo
532 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
