Omega he60 not blowing air
Hi I have an Omega HE60 and when I turn up the external dial it clicks and nothing happens on the main unit now, it doesnt blow any air at all,
I switched it off at the mains and it started to blow once now it does nothing at all, please help
    Scholar:
  • 70 Answers
Check for bad breaker. Check power where it enters heater. If It has power check for broken or burnt wires or bad relay switch or thermostat.
Posted on Jun 30, 2009
Driver for pc camera OMEGA
Hi and welcome to FixYa
Since you didn't specify your omega camera model here is a link with all the omega web-cams models
http://www.omega.com.tw/support.asp
Just look where it says web cams and choose your model to begin download the driver, then double click on the file to begin the installation.
Hope this information was helpful
Sincerely,
aDynamite.
Feb 28, 2011 | Computers & Internet
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
Have omega mars-22 goes through cycle like lock unlock doors security lights flash,but when you hit the start button on remote it does nothing,doesnt even try to start the truck worked fine before any help...
Try this
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Nov 24, 2009 | Omega MARS-22 Remote Vehicle Starter with...
I have an evaportating cooler omega it only works on fan.
I would have the unit looked at. The auto section on the motor is turned on by the cooler automatically so there seems to be a problem there at that switch.
Good Luck on your repairs hope this helped some
Dave
Nov 09, 2009 | Heating & Cooling
Can i replace automatic movement for quartz in a james bond model , and can i do this myself
You can if you have following:
1) Lathe technique skills,
2) Watchmaking skills,
3) Watch engineering knowledge,
4) All necessery watchmaking hand tools,
4) Watchmakers lathe,
6) Microdrill,
7) Omega or ETA manufactured quartz movement
8) Original Omega dial for this particular movement,
9) Watch hands for this particular dial.
At the very end your watch will have no market value at all exept sentimental value for yourself.
Rate me, please.
Aug 22, 2009 | Omega Seamaster 2253.80 Wrist Watch
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
