Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Piston pump on my sand-point works well with plenty of suction, seems my point is blocked, is there any way to solve this problem without removing?? Michael walshmp@magma.ca
  • 1 more comment
  • walshmp Jun 30, 2009
    It,s a sand point well, the point is the pipe that goes into the ground/sand which I believe is clogged.
    I am looking for away to unclogg this part.
    Thanks
    Thank you for your reply it is most helpfull. If I pull the point how difficult will it be?? Its about 14ft into the ground and if I manage to get it out how much trouble can I expect to get it back in.. Thanks.
  • walshmp Jul 02, 2009
    Great help. Thanks
  • 15,935 Answers
Please clarify "point". Do you mean the output port?
If there is suction and it is working well - how/why do you feel the outlet is plugged?
In what application are you using this pump?
Please use the "Continue with this Expert option" to reply to these questions.
Thanks!!
Posted on Jun 30, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jun 30, 2009
    Your screen is probably getting plugged up and may need to be pulled if treating with Nu-Well tablets does not help.
    There is a product called Nu-Well tablets. They are made by the Johnson company and are designed especially for treating encrusted well screens. The work is done at the screen by a slow dissolving tablet. Water must be added to the well continuously for them to work good as they must be dissolved to make the acid that does the actual work.
    You defined your well as a point well, so I would assume there is no check valve in the well. If there is, you will have to pull the point. If the well is 1-1/4" it has no checkvalve in it. If it is 2" it could have a Bremer check on top of the screen which will render the Tablets useless.
    Most well drillers' supply stores carry the tablets....
    But if you are having a hard time finding them in your area - i KNOW BJW sells them....
    BJW Berghurst & Sons
    Holland, Michigan.
    616-772-2114
    $25.50 per half gallon (More than enough for your use)
    Remember if you have a check valve in that two inch well, don't use the tablets. They won't work.
    Thanks for using FixYa!!
  • blueextc3221
    blueextc3221 Jul 01, 2009
    I would say once you pull it - there's no way to get it back in - depending on how long its been there of course. It would require a well drill & liner with constant pressurized flow to expel the sand.
    Try the tablets :D
    Thanks for usinfg FixYa!
  • blueextc3221
    blueextc3221 Jul 02, 2009
    If you feel I've helped you out.... please change your rating to FixYa - so it can be cleared from the work Queue
    Thanks :D
  • 790 Answers
Hi
The best is to remove the pump cover to remove the clogged and clean the jet pump,. i think this is the best way to solved your problem
Thanks!
Posted on Jul 02, 2009
    President:
  • 2,187 Answers
It would depend on how much has clogging you have in your system. For almost all piston pumps, the orifices of the pump would need cleaning. Pressurized air to force impurities out be a nice way to do it, on the engine or on the pipes. Check if it is just the pipes you need to clean out, this for sure you may not need to take out the engine. If the pipes checked out OK that would be the time to check out the engine.
Plenty of suction with hose off, little suction with hose and head on. No clogs in hose or head.
if it works without the hose attached but not with it on , then there has to be a blockage keep looking for it .
May 10, 2016 | Miele Vacuums
How do I fix a suction problem on my pool pump?
If return inlet fittings are STRONG with plenty of water returning, then that means water is being sucked from somewhere else in addition to your weak skimmer, Right?
So that means you must have another point of suction somewhere that is also open, especially with knowing, that suction at skimmer is weak!
To increase suction at any one point, close down other suction ports. In your case probably a second skimmer that is "tee, d" together, then in which case you will need to physically plug that openings suction port, if there isnt a valve to do so. Or your bottom main drain is open ?
May 04, 2015 | Pool & Spa
My sand pump won't pump water back into pool?
No such thing as 'sand pump'...
There's a circulation pump and sand filter.
filters don't pump water.
if no water is flowing, then pump is either not primed, or valves are closed.
Or water level is not at point of water entry into suction port.
Mar 29, 2015 | Pool & Spa
My water lines always have air in them, alot of air! I do not get alot of water, The pump seems to run along time with, no results. I have an old piston pump, the repair man that was here removed the jet...
Is there water visible in the well,or do you have a point ,nonetheless if the pump is running for a long time,then there is not enough water,or the suction side of the pump is drawing in air ....the pump will suck in air easier than pulling water up into the pump,the suction side cannot leak at all !!! If you have a foot valve it may be faulty also !
Good luck
Feb 22, 2015 | Garden
Swimming pool Hayworth s240 sand filter suction is wimpy can it be old sand causing the problem?
The filter may be clogged. If you have a multi-port valve that you use to backwash, set it to "recirculate" and see if your suction improves. If it does then the filter needs to be cleaned out. If there is no difference the issue may be a clogged impeller or some restriction in the suction line. Has the pressure been running high?
May 19, 2013 | Pool & Spa
My new Optiflow pump surges..............it seems to not be pulling the water thru the sand filter and discharging as it should. Sand filter gauge fluxuates between 0 and 3 lbs of pressure.
it sounds like you may have a suction side leak on the pump. check the lid o-ring and the suction side fittings to see if there may be a possibility of air being sucked into the pump and causing it to act like it's picking up prime and then losing it.
Jul 25, 2011 | Pentair OptiFlo Aboveground Pool Pump 1 HP...
I got 1 year old flotec 3/4 hp pump and it take
I have had the same problem there are a few things that can cause it to take longer to shut off, if you are running a sand point well that's usually a sign that the sand point is clogging up,if you have a sistern or a dug well check the screen on the end of the suction pipe,another possible cause is the water level has dropped low enough the pump is having to work harder to pull the water up, you should also check your pressure tank and the points for the pump if the points are sticking the pump will keep running till it builds enough pressure to trip them.Check for leaks in the suction line, if it is sucking air that would cause it to run longer to.I hope these suggestions will help fix the problem. Have a great weekend
Sep 05, 2009 | Flotec Plumbing
2008 vx110 waverunner... friend ran into shallow water (sand) where he said he got stuck (sand bar) light came on (probably overheat) and engine stopped... engine will crank but wont start..what to check?...
The damage that can result from overheating an engine would be piston seizure. Without the cooling water circulating around the outsides of the cylinders to dissipate the heat from combustion, the piston temperature rises higher and higher. As the piston(s) get hotter, they expand. Being aluminum, they expand more than the liner of the cylinder does, and eventually expand to a size bigger than the cylinder. That is when the seizure happens.
At this point, you need to do a compression test on all 4 cylinders. You should have at least 150 psi on each cylinder. Anything lower than that is indicative of a problem.
Jul 13, 2009 | Yamaha 12V Air Pump
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
206 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
