Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Projection display just bought this clock/radio. The display on the wall/ceiling does not work. It shows somethings but you cannot read the numbers, they are not complete.
  • ChemESGH Dec 25, 2007
    Just received this for Christmas and having problems with the projection clock. It got stuck on 7:53 after the atomic clock synced up. I pulled the batteries and unplugged it to reset everything and now it shows unreadable numbers.
  • cricket76 Feb 07, 2008
    I am having the same problem. I have tried to change the focus, but it is still is unreadable. I have only had my clock for a little over a month. Everything was going great so I threw the box away and then this happens. Hopefully it is an easy fix.
I had the some problem a few days ago when we had a power outage during the night. Try unplugging it, leave it unplugged for about 10-20 seconds, and replug it back in. Reset your time on the clock and it should work then.
Posted on Oct 01, 2008
Time is projected upside down on ceiling, can that be corrected
Here is the link to the manual. There is, on page 3, instructions on how to rotate the projected display. A button will move it 90 degrees at at time. Twice should do the trick.....
Dec 10, 2015 | La Crosse Technology LaCrosse Technology...
The battery was replaced, display went blank, how do I reset !!!
What is the exact model number and brand name of your clock radio?
Apr 23, 2012 | Audio Players & Recorders
The projection light will no longer show on the ceiling....I have only had the soundspa for about 6 months
see if there is a factory warrenty on the bow or with the papers it came with maybe theyll have one
Jun 11, 2010 | Homedics Sound Spa Premier SS-5000 Clock...
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
Static occurs when movement in the room
This problem sound like you have had some damaged to the earth ground in your electrical wiring system. You should have a electrician thoroughly test the electrical outlets and wiring in your house or apartment. You should be very careful using any electronic equipment with a problem like this. Your Clock/Radio should be unplugged from the a/c wall socket and the internal battery removed. This will allow the microprocessor that controls all the Clock/Radios functions to reset. The Clock/Radio should be left unplugged for a period of a few hours to discharge the microprocessor. This will help the microprocessor to heal itself from the lightning strike. You will need to get the ceiling light fixed. There might be a shorted wire or something causing its failure. This could also be a burnt wire. Lightning power overloads can be very dangerous to all electric and electronic equipment. Try putting your clock Radio on a rubber mat to isolate it from any traveling static electricity that may be in the air. Try to discharge any static electricity that may have built up on your hands by discharging it on a piece of metal like a screw driver or metal surface.Do this each time before you try to use the clock/Radios button functions. This will stop further damage from occurring during you handling of the Clock/Radio. After discharging the microprocessor, reassemble the battery into the Clock/Radio and plug in the wall socket. The operation should return to normal. If not you may have more serious damage to the microprocessor. You can call the Emerson Customer support at this telephone number 1-800-898-9020. Give then the make and model number of your Clock/ Radio and ask them for assistance. I hope this information helps you with your problem.
Feb 09, 2009 | Emerson Smartset Clock Radio
I have a new Emerson CKS3528 clock radio with projected clock. The LED clock reads the correct time, which is 4:30pm, but the projected clock reads 9:30am. What should I do?
Sorry it took so long to give you some help with your problem.I hope You have returned the Clock/Radio for exchange at the place of purchase. If Not I hope You contacted the Emerson Customer Support and told them about the problem you are having with projection display malfunction. I hope they were be able to help you with the problem. if you have not already done any of the above, The contact Telephone number for the Emerson customer support is 1-800-909-1240 between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day.
Dec 25, 2008 | Emerson Smartset Clock Radio
Sentry CR-106: setting the projector's time.
I found my manual!
To set month, press the "set" button 2 times then press "mode" to sequence month
To set date, press the "set" button 3 times then press "mode" to sequence date
To set hour, press the "set" 4 button times then press "mode" to sequence hour. (24 hour clock toggles with 12 hour clock)
To set minutes, press the "set" button 5 times then press "mode" to sequence minutes.
I hope this helps!
Oct 07, 2008 | Audio Players & Recorders
Emerson Smart Set Clock Radio CKS3095S
You need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C source. You must also remove the internal battery (CR2430). You must let the Clock/Radio set without any power source for at least 3 hours to allow all the power to drain from the microprocessor. After the power has drained from the microprocessor, you can reinsert the internal battery and reconnect the Clock/Radio to the A/C power source.Now test the Clock/Radio, to See if the functions have returned to normal. If they have not returned to normal,unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace this battery with a new Battery (CR2430). Let the microprocessor drain all the power out. Then reinsert the new battery and plug the Clock/Radio in to the A/C power source. The Clock/Radio functions should have returned to normal. If this is not the case, then you may have a more serious problem with the Clock/Radio. You will need to call the Emerson Customer Support. The Emerson Customer Support Telephone number is 1-800-909-1240. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you solve your problem. Thank you for using FixYa and have a nice day.
Jan 26, 2008 | Emerson Smartset Clock Radio
Remote Weather Station shows "HHH"
This means that the read is over the HIGH limit of the sensor, perhaps is too hot there. Change it to another location. josemaX
Jul 30, 2007 | GE 75295 Clock Radio
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
517 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
