When I connect my samsung vice to my computer, it doesn't show up. Under computer management there is a yellow question mark (usb) when i click update device- it says hardware not installed.
  • Stephen Jun 30, 2009
    Thanks anyways, but I used a card reader and transfered the data that way instead of spending time looking the drivers,
OK. I solved it. On my phone in the main menu you go to "Entertainment">memory card>connect with pc and all is well. You can copy files to and from the phone as you would any storage device.
I modified this solution I found. My setup doesn't have a "video" option under the main menu. It's called entertainment.
http://answers.yahoo.com/question/index?qid=20090702145143AAAbVxs
Posted on Sep 06, 2009
    Problem Solver:
  • 6 Answers
Some computer programs will not allow u to use certain usb devices on them try getting or using a different computer
Posted on Jun 30, 2009
I've have a samsung corby mate mobile. When I connect my mobile to USB, the system didn't recongise it.
connect your corby mate mobile using your usb connection
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
it might be listed as a mass storage device
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 02, 2011 | Computers & Internet
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
I've a 16 gb pen drive when i connect it to my pc it shows " USB device not recognize" & on further details it shows error code 43..... I've very usefu data on the same pen drive plz...
right click to reinstall drivers if you need any more help just post a reply
hope this helps
Jul 23, 2011 | Computers & Internet
Computer doesn't show that device is connected
if your computer came with a motherboard disc the drivers could be on it
right click to reinstall drivers or
if you can see your usb but its not working
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 11, 2011 | Western Digital My Book Essential 1TB...
For some reason I can no longer access my Cruzer Micro thumb drive. When I plug it in the PC does make the tone that it recognizes something is plugged into the USB port but when I open My Computer it does...
hope this helps
Jun 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Samsung Pleomax Ultra-Portable UHD-12G - hard drive - 12 GB - Hi-Speed USB. I think the autorun was deleted off of this flash drive. The computer does not see it at all. There are no yellow x's under...
This could be an issue with assign the drive a letter:
1. Right Click on "My Computer" (might be called computer)
2. Left click on Manage
3. On the left click on "Disk Managment"
4. Check to see if the 12GB USB drive is showing up there if it is then right click on it and assign it a drive letter.
If the USB does not show up in "Drive Management" then try another USB port or another computer to test to see if the USB drive shows up.
Hope this helps
Mar 07, 2011 | Samsung Pleomax Zirex UHD-12G 12 GB USB...
When i connect my kingston usb,system doesnot recognize it (no display or folder in my computer),only beapsound produced, but ports are not damagd & usb is working properly on other systems
have you tryed other usb ports? try goign to device manager, right click on my computer icon on the desktop click on then click on manage then click okay if a window pops up, now once computer management opens look at three options click on system tools then another list will show then click on device manager that should show if the system has read it or not normal if it doesn't reconize it will show a yellow question mark same as inproper install of driver. Also try getting the driver fo it and install driver first then connect that too can be a problem. hope this helps.
Nov 07, 2010 | Computers & Internet
When I plug in the flash drive it lights up but doesn't show up as a drive in "my computer". If I start the device manager (which shows the cruzer device as a funtional drive), disable it and...
STEP 1 - Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: The Cruzer might show up under several places under Device Manager such as:
1. Disk Drives
2. DVD/CD-ROM drives
3. Universal Serial Bus controls as USB Mass Storage.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
SOLUTION 4 -
There might be a conflict in drive letters, see Resolving drive letter conflict.
Oct 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
Computers & Internet Logo
3,497 people viewed this question
David Payne
David Payne
