Question about Whirlpool Calypso GVW9959K Top Load Washer
Our whirlpool washer gvw9959kq2 won't drain. All of the troubleshooting tips say to unclog the hose... but it doesn't say how. How do we unclogged the hose AND how do we get "stuff" out from under the washer plate?
  • saragw2008 Jun 30, 2009
    How do i remove the front panel?
    Got the hose out and found "gunk" and several pennies that were worn almost down to nothing! Hopefully that will do it. Now need to reassemble the beast:)
  • 999 Answers
Remove the front panel and the hoses will be accessible. Removing the wash plate is not advised unless you are prepared to replace seals.
Eric
Posted on Jun 29, 2009
  • Eric Duda
    Eric Duda Jun 30, 2009
    It has been awhile since I've seen a Calypso but I believe it is held in place with clips. Slide a plastic putty knife between the top and front panel near the corners.
    http://www.searspartsdirect.com/partsdir...
  • Eric Duda
    Yes those are a "joy" to service. Congratulations!
How do you unclog washer drain
Hey friend, thanks for your inquiry!
I understand that you would to unclog your drain on your Frigidaire washer. I would recommend having a professional come out to unclog your drain because this would acquire some disassembly of your washer. These intricate parts do require precision and patience and I would suggest having a technician come out to avoid any potential harm. -Matt
Aug 22, 2014 | Frigidaire Washing Machines
Does not empty after final spin cycle I have checked the pump and hoses. The only thing I see may not be right a cylinder shape is in the boot at the outlet.
Hi Peter,
So I see that your Frigidaire Affinity washer is not draining completely after the final spin. I also see that you've checked the pump and hoses as well. There are a couple of other troubleshooting tips I might suggest.
1) Make sure the standpipe isn't too tall. Maximum standpipe height should be 8' (2.4 m).
2) Check the house drain pipes to see if they are clogged. If so, unclog the drain pipes. Contact plumber if necessary.
-Best Regards-
Jan 23, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Whirlpool Washer with FL error code
Check the hot and cold water supply must be going to the machine
Dec 19, 2017 | Whirlpool Washing Machines
Washer doesn't spin drain
remove the drain hose at the back of the washer and check that the filter is not blocked.
Feb 24, 2012 | GE Washing Machines
Water pump is clogged on my maytag front loader how do you unclog it? I washed old tugs that had rubber backing and they fell apart and crumbled
Unplug the dryer or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Maytag machine is made by Whirlpool and therefore troubleshooting are basically the same. Click on link below for more detailed drain problem troubleshooting.
Drain Problem Troubleshooting on Whirlpool-made Front Load Washing Machines
Jul 19, 2011 | Maytag MHWZ400T Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
791 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
