Question about Samsung Televison & Video
We have a Samsung HLT5676SX/XAA projection tv. When we hit the on switch, the sound of the tv powering up then it clicks off. What is our problem?
  • 8457 Answers
SOURCE: Samsung HCL4715W red light indicator is on, but TV does not work
Ur backlight video board is dead,must replaced.
Posted on Dec 10, 2009
  • 192 Answers
SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
easyab
  • 132 Answers
SOURCE: Samsung rear projection television HCN4226WX/XAA
Dead Samsung
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Most rookies will not successfully complete the repair and probably do more harm than good.
Sometimes when the convergence chips fail, the TV senses the changed load condition and shuts down.
Unplugging the blue, red or green convergence connector on the convergence board removes the overload condition if the IC is shorted and allows the tv to run, with one color missing.
This is done with the tv unplugged. Then plugged in and turned on to see if it starts. Turn off immediately if you here it start.
Now you know if convergence failure caused the shutdown. You can repair the convergence circuit if that is the problem.
If this has no affect, then you could have a number of different faults in Vertical output, Power Supply or HV circuits that require the expertise of a qualified service person. This would be a bench repair in most shops.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Posted on Jun 27, 2008
  • 98 Answers
SOURCE: Samsung LNR408DX/XAA Powers on with sound but no picture
I think you need to exchange the Main Board.
Posted on Feb 06, 2009
  • 197 Answers
SOURCE: i have a samsung hl-s6187wx/xaa standby light
bad color wheel
Posted on Jun 07, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a Samsung HLT5676SX/XAA tv that will power on then goes right back off what does it need to fix it
Hi, it seems that TV has a faulty component or board, if you don't have skills to fix electronic devices, it's better to ask for qualified technical service to check your TV.
Nov 13, 2015 | Samsung Televison & Video
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
How do i open the back to install lamp on my samsung56 mod hlt5676sx/xaa ?
Click Samsung Support to download user manual copy and check page-74 that has detailed instruction about lamp replacement in this TV.
Nov 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
633 people viewed this question
Jerry Greenberg
Jerry Greenberg
