Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-40xbr800 standby light blinks 7 times.the tv remains off
I started having the same problem.
Started 2 weeks ago.
I here frkn. relays click, but hothing happens.
First it did it sporadically.Now it wouldn't turn on at all.
I also tend to believe that it was set to die in 2009.
Any thoughts?Solutions?
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Posted on Sep 09, 2006
  • 668 Answers
SOURCE: my sony standbt light is on. no pitcure
The "D" board has probably failed. Most of those boards are not available from Sony but can be sent to Sony for Refurbishing. The 'D" Board has the Deflection , Protect, and most of the PowerSupply incorporated on it. Most of those Boards are also Double Print/Multi Layered style boards that make it difficult to repair at a component level.
Best thing to do in mt opinion is to call Sony at 100222SONY and see if they can refer a Service Facility to you if you are willing to put 600.00 to 800.00 into it.
Hope this helps,
skyassoc
Posted on Jun 22, 2009
alpug
  • 1961 Answers
SOURCE: Sony WEGA KV-40XBR800 Standby light blinks seven
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Posted on Jun 14, 2010
SOURCE: sony kv-40xbr800
Exact same problem. KV-40XBR800 wont turn on, blinks six times. I am in the process of changing both Ic's part# MCZ3001D with part# MCZ3001DB. Ordered them frm ebay and waiting for the new parts to arrive.
here are the pictures of both chips and after i removed them from the d board.
As soon as i receive the new ones i will put them in. I can't wait to see what happens and i wanted to say thanks to all of you out there for putting this thing up. Thank you very much.
Posted on Jul 02, 2010
Sony kv-40xbr800 blinks two times
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Jun 09, 2012 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have a Sony kv-40xbr800. The standby light flashes 6-7 times and does not turn on. If left off for a couple of day, it may turn on. Is there an easy fix?
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Jun 05, 2010 | Televison & Video
HELLO I HAVE A SONY 40XBR800 TV. WHEN I POWER THE TV ON THE STAND BY LIGHT STARTS BLINKING AND THE TV DOES NOT COME ON
My Sony XBR800 won't start and the standby light blinks 7 times with a 3 sec. interval before blinking again.
Aug 30, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
471 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
