I have a front loader frigidaire LTF2940ESO that is not spining, I put a heavy blanket in there and after that it quite spinning, it trys to run thru the cycle but does not move.
I had the same problem. On mine a shock mount broke and allowed the basket to impact the control assembly. Several wires were damaged and connectors were knocked loose. I repaired it but now BOTH shocks are broken and I'm shopping for a different washer.
Posted on Oct 06, 2009
  • 56 Answers
Sounds like a problem with the door lock check that all the wires are on tight
Posted on Jun 30, 2009
Fridgedaire front loader only goes into High spin with a light load.heavy load won't go into High spin
Product Support & Manuals - Frigidaire
www.frigidaire.com/Owner-Center/Product-Support-Manuals/
FrigidaireFind appliance guides and manuals, FAQs, information about accessories and more. Get all of the answers you need about your Frigidaire appliance today.‎Dishwashers - ‎Ranges - ‎Window Mounted Air ... - ‎Washers
Sep 10, 2015 | Washing Machines
Error Code E65 on Frigidaire Front Loader Model #LTF2940ESO
Thermostat issue - need a professional to complete the following:
For electric model, check inlet thermal limiter for continuity. If thermal limiter is open, check for evidence of high temperature event and any resulting damage. If no further damage is evident, replace thermal limiter. If no problems are found with the thermal limiter, check exhaust vent system for air blockages. If no problems with vent restrictions, check/replace high limit thermostat, and retest.
Aug 15, 2012 | Frigidaire Washing Machines
Is there any way to adjust my front loader Samsung to have more water during the wash cycle? I was washing one light blanket and during the wash cycle I had to add a dish towel, when I put my hand into...
Hello
Remember this washer is a water saver.I have the same question on my new washer.What i do is increase the size of the load.
Instead of running it on light load, ill put it on heavy this will allow more water to fill.
May 04, 2011 | Samsung WF203ANW Front Load Washer
My front loader will not spin and drain completely can you tell me what may be causing this problem? thanks
the pump is clogged so,put Draino-max in the drum and wait 1-2hrs. this gets rid of the pet-hair strings etc. out of drain.Run on heavy-duty use hot-water it may take 2-cycles to open the drain,also chek to see if hose is not clogged.
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Not spinning water out of clothes
CHECK OUT THE DRAIN MOTOR PUMP , it cpould be clogged , located where the drain hose is connected inside , youre gonna see 2 hoses connected to thi small motor , hope it helps , AJ
Nov 16, 2009 | Frigidaire GLTR1670A Front Load Washer
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Front loader not wringign out water
Details? Is the machine SPINNING? That would be the first thing to check for, make sure the spin cycle is working as that is what gets most of the water to wring out. Some times if you have heavy towels and blankets you may have to run the spin cycle twice, if your machine is getting older, I would check that out FIRST.
Jun 19, 2009 | GE WBSE3120B Top Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
373 people viewed this question
Top Washing Machines Experts
