Question about Garden
I have a hole in the water hose to my pressure washer. Can I fix it or do I have to buy a new pressure washer? Loraine
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
CRTN
  • 716 Answers
SOURCE: High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a honda 2600 pressure washer. After
This is a symptom caused by a sticking Unloader valve. The Unloader valve is inside the pump outlet body under the large black knob.
Example picture : http://www.msservice.net/product_spotlight.html
Before doing any dis-assembly try this procedure first. This may sound weird but it often works. We do this with a short piece of garden hose,,,,, Add 3 to 4 ounces of engine oil into the water inlet by pouring the oil into and old short / cut off garden hose with the end elevated but connected to the pump inlet.
Slowly pull the engine starter cord so as to pump the added oil into the pump and let it sit over night. Just keep pulling the starter cord "IGNITION OFF" until you note oil exiting the high the high pressure hose connection.
Then connect everything like you normally would the next day.
MAKE sure to purge the water supply hose of air at the pump connection before starting the engine.
Start the engine. NOTING that your going to shoot out the oil you put in the day before..... Pull the wand trigger every 3 to 4 seconds so you cause the Unloader / thermal relief valve to stroke within the pump body. Don't give up... you have to do this for an extended period of time so that you have HIGH pressure each time you pull the wand trigger.
With the engine still running.... let it run trigger off for about 1 minute at mid engine speed. Pull the trigger again and see if you have high pressure. Do another long pause... then use as you normally would.
IF the above lubrication process does not work....
The Unloader / thermal relief valve needs to be dis-assembled so that the springs and seals can be lubricated with Lubriplate #105 white grease. Make sure to also lubricate the casing of the pump body before putting everything back into the pump body.
Here is the white grease tube your looking for at any automotive parts supply.
http://www.lubriplate.com/products/greases/no-105-motor-assembly-grease.html
This should get you going again. Just note that Unloader valves will notoriously stick after end of season storage upon the next use. It is important after an extended non-use period that the wand trigger is cycled every 3 - 4 seconds to exercise the Unloader valve springs and seals in the pump body. You only need to do this for about 45 seconds.
Thanks for choosing FixYa,
Kelly
Posted on Jan 18, 2011
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
Coleman 2400 PSI Pressure Washer - WATER LEAKS OUT = ?!? Help me please!!! ((-:
Usually, there are spaces between the pump and head portion of the pump. This space is not sealed and will allow water leaking past the seals to come out. There may be a seal kit available, however I have had better luck just changing out the whole pump. There are many available on ebay. Search for one that will use same mount and hoses. Once the seals are gone, the pump will never be the same (may nickle and dime you the death).
Oct 30, 2011 | Garden
Water leak where the gun hose connects to the washer causing very low pressure 2200 psi model 020245
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Jun 08, 2011 | Garden
F8E1 on my whirlpool duet WFW9150 front load washer. 4th time in 8 months...(bought brand new)
I too had the same problem and what I found (besides poor workmanship in the design of this washer) is that the pressure switch hose had rubbed the drum and there was a hole in it - leaking water, which I hadn't noticed until I sat there and kept re-running washer til a puddle had shown up below. They wire tied the top of the hose to the drum but at the bottom of the hose there were no wire ties and so the foam padding that was wrapped around just kept rubbing until it ripped and then left the hose exposed to the drum. They should have never tied the hose to the drum and should have attached the hose to the right cover. I will be modifying their design as soon as my new hose arrives.
Nov 28, 2010 | Whirlpool Duet WFW9550 Washer
When pressure washer is running no water is
Most of the time the problem is just debris in the spray nozzle. The hole is very small and it doesn't take much to clog it. If you can remove the nozzle, just take a pin or small piece of wire & poke it through the hole from the front of the nozzle and rinse it off with the hose. If the nozzle cannot be removed, just take the lance apart in the middle and do the same.
Feb 05, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Pressure washer has no pressure coming out
I think yor hot water softened one of the pressure seals and has allowed it to buccle. This will drop the pressure away from the pump. It will require new seals to be fitted and the cost is close to $200.
Aug 14, 2009 | Garden
Have hole in water hose to wand. can it be fixed
you cannot fix the leak, you must replace the hose.
Jul 14, 2009 | McCulloch FH160G Pressure Washer
Mar 11, 2009 | Garden
Oasis water level problems
Most likely, your tape is not holding the pressure and the machine starts filling because it thinks the water is low. The new hose should fix the problem. If not it will probably mean a new control.
I would also like to know the location of the rub hole on the hose. What was it rubbing against? Thanks/Mike
Oct 21, 2007 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
