SOURCE: Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
SOURCE: no sound from front right and left speakers
you may have a dc condition present on speaker outputs. this could be caused by dry solder joints, suggest blanket resolder of the output stages for front channels.
SOURCE: I have an old Kenwood receiver that does not power up
If the voltage was 110, the polarity should not have made a difference. In all probability, the input power transformer has an open primary. This can happen with a power surge or just because of age. If you have an Ohmmeter, with the unit unplugged, measure across the 2 input pins for the main transformer. It should read about 3 ohms or less. If it reads infinity, it is open and must be replaced.
Keep us posted,
Dan
SOURCE: Kenwood VR-509 Receiver won't power up...
Check all your speaker wires for shorts, especially behind the amp, doesn't take much for something to throw a spanner in the works, like when cleaning house and moving stuff around.
SOURCE: receiver makes clicking sound before power shuts
What you are hearing is the speaker protection relays. See the link below for a generic explanation of protect mode (the mode your unit is in at the moment.) Update this if you have some test gear and wish to attempt to repair this.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
