Question about Dryers
Kenmore dryer 110 708 12990 Igniter glows, but
Kenmore dryer 110 708 12990 Igniter glows, but burner flame goes out before clothes dry. Already cleaned all vents and inside dryer.
  • 56 Answers
Replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Posted on Jun 30, 2009
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Aug 21, 2014 | Kenmore Dryers
80 series kenmore gas dryer. Won't dry clothes. Igniter glows, gas valve opens, flame lights. Stays on for about 45 seconds then flame shuts off. About 1 minute later it lights again but it doesn't stay on...
Did you get a solution yet? - our dryer is doing the same exact thing....last time it was not lighting at all and we found out it was the thermal fuse - very cheap fix...this time the symptoms are exactly as you described.
Aug 03, 2010 | Kenmore Dryers
Dryer is tumbling properly,but not drying. there is absolutely no heat.
pop the cap on the front of the dryer an turn it on
if you see the igniter glow an the flame comes on wait an see if the flame stays on if it it shuts off like 10 sencds later,you have a block vent
if no glow or flame u got a bad thermal fuse
if it glows ,flame an shuts off like and then comes an goes u have bad coils...
good luck post some feed back thanks
Feb 01, 2010 | Kenmore Dryers
My kenmore dryer has the motor running but it has no heat. My clothes don't dry at all.
I've had this happen twice. It's the small flat thermal fuse and it costs about $5 online and is easy to install. Sears wants $100 to do this, maybe more now days.
Oct 29, 2009 | Kenmore 73952 Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 11, 2009 | Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
283 people viewed this question
Top Dryers Experts
