A
Anonymous Posted on Jul 24, 2014
Where can I find the 1/2 inch wife labeling tapes used in Scotch brand (model EA-450) label maker? Label maker is over 20 years Old.
Mr Williams
Level 2:
New Friend:
  • Expert 137 Answers
  • Posted on Jul 24, 2014
Mr Williams
Expert
Level 2:
New Friend:
Answers
137
Questions
Helped
36397
Points
343
If you can get an accurate measurement of the label, you might be able to find another label series that might work. Other than that, I don't know. Maybe Ebay?
1 Related Answer
Anonymous
  • Posted on Dec 29, 2008
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Dymo PC 10 electric label maker. Looking for cables?
Are you sure is is a 'PC 10'? I can't find that model. All the ones I have used were battery operated desktop use or hand held. Is this a cable that connect the label maker to a PC, so you design on the computer and print to the Dymo? If that is the case, It _should_ be a standard printer lead.
10FT USB2.0 Printer Sync Cable For DYMO Label Writer ...
Walmart https://www.walmart.ca > 10FT-USB2-0-Printer-Sync-...
100% BRAND NEW, NEVER USED; Cord Length: 10 feet 3M; Compatible with: DYMO Label Writer 450 Twin Turbo label printer; PC and Mac compatible ...
· ‎In stock
USB Cable Cord for DYMO LABELWRITER 310 320 330 ...
eBay https://m.ebay.ca > ... > USB Cables, Hubs & Adapters
USB Cable Cord for DYMO LABELWRITER 310 320 330 400 450 TURBO LABEL PRINTER 6ft ; Quantity. 3 sold. More than 10 available ; Item Number. 364268793499 ; Brand.
NiceTQ Replacement PC/Mac USB Data Sync Transfer ...
Best Buy https://www.bestbuy.ca > ... > USB Cables
NiceTQ Replacement PC/Mac USB Data Sync Transfer Cable Cord For DYMO Label Writer 450 Twin Turbo Label Printer. Model Number: 308139549170. Web Code: 14840651.
· ‎In stock
Dymo PC 10 search results.
https://www.google.com/search?q=dymo+PC+10+electric+label+maker
Brother P-Touch label maker won't print. The tape is feeding out but no letters.
Question edited for clarity and add maker.
There are many models under the P-Touch brand, so generic answers only but in 90% of cases it is an incorrectly seated cartridge..
https://www.google.com/search?q=p-touch+label+maker+not+printing
I just replaced my bottom ball joint and my new one came with a c clip do I have to put that on
the answer is yes. use the snap.
if no snap ring grove , ?that is a chinaa clone?, junk or wrong one.
why not tell maker and model new joint to make this 10x more easy
gee, you do not want to have any joint fail at 85mph, right.?
(dallas freeway way legal),grin.
i found the ring is there for using new joints, to old worn arms
may car dealers only use new arms to avoid this. danger.
but aftermarket sellers add the ring for those using old arms,
and add a snap ring for added safey,<<< here is your answer.
best is ask , the joint maker this, of many,
I'd bet the all say use the SNAP. on old arms. every time.
I can not see your old one or new one. nor.
no maker of new ball told.
Lower joint
let me guess not from dodge?
lots of 3rd party brands.
there is no one joint here, at 3 types, some are listed as
lots of variants, but less 4wd,
I like this maker, , old tried and true records USA.
MOOG, eCATalog shows
https://www.moogparts.com/find-my-part/find-my-part-results.html?type[value]=2&type[label]=Light%20Duty&year[value]=1999&year[label]=1999&make[value]=40&make[label]=Dodge&model[value]=2760&model[label]=Ram%201500&subBrand=bcch
moog.com show 4wd + snap
Part No: K8195T
https://www.rockauto.com/en/catalog/dodge,1999,ram+1500+pickup,3.9l+v6,1354126,suspension,ball+joint,10070
Where can I find the 1/2 inch wide labeling tapes used in Scotch brand (model EA-450) label maker? Label maker is over 20 years Old.
I have found these at Staples and Office Depot, probably other places have them or if you just want them sent to you check Amazon.
1helpful
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
1helpful
Numbers have rubbed off oven prima
Welp, you're gonna have to get yourself a cheapo oven thermometer and relabel (sharpie or label maker, or tiny paint pen). Most ovens aren't very accurate according to their labels anyway, so you'll have to experiment with the thermometer and some labeling. If ya want to be slick, you can get some clear contact paper or similar, tape out some basic temps, then print out a label with them all. But a plain old label maker will probably work fine.
Feb 18, 2013 • Cooktops
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
k24674
ADMIN Andrew
ADMIN Andrew
