Question about Craftsman Garden
Tecumseh Sears Eager-1 6HP mower will not start.
I am working on a Sears Eager-1 6hp self-propelled walk behind mower (Model# 143.956002) for a friend. He said he changed the spark plug, and it started, then died, and now will not start. I've taken the carb apart and cleaned all the jets/orifices/etc. Everything there looks okay, so I started looking at the ignition. When I check for spark with an in-line spark tester, it lights up, but I can not see a spark at the plug when I ground it and try to turn over the engine. Wondering if anyone has any ideas, or knows what the resistance should be across the coil? The spark plug is gapped correctly, and we've tried 2 different brand new plugs.
  • paradoxrx7 Jun 30, 2009
    I held the plug against the block with gloves, and even watched it in the dark. after cleaning the block with a wire brush. I'm not thinking it's compression, because it ran fine then stopped, and it sounds like its getting pretty good compression when turning it over. (I don't have a comp tester handy) Fuel is getting to the carb and filling the bowl.
I have an old craftsman Eager 1 self propelled 5.0 mower. I have been looking for a manual. The model # looks to be 131.4402 its hard to read. So far I have come up with nothing.
Posted on Jul 08, 2009
I have a series 725 briggs and stratton engine in my 2013 craftsman lawner mower. It runs well when mowing except when I start to bag clippings. After 3 bags, it will not restart for about an hour.
are u bagging wet tall grass ? could be bogging down the motor and getting to hot ,this has happened to a self propelled walk behind craftsman 6hp
Aug 26, 2017 | Craftsman Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Model 10640 how to adjust self-propel drive cable
If the V-belt is old, you'll need to install a new V-belt first ,then IIRC,the adjustment is by sliding the bale conduit on the side of the handle.
Jun 16, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Toro 6.5 HP Self propelled walk behind 22
take the top cover off the engine. you will see the coil on top there. unplug the wire that plugs into it. put the cover back on and try to start it. if it starts it is not the coil. try a different spark plug first. pull the cord with the plug out to get all the gas out of the engine.
Mar 20, 2017 | Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Sens-a-speed mower rear wheels lockup when trying to push mower when not started or running
this means that the self propelled is engaged the whole time. so you need to somhow disengage it
Aug 19, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Oil drain
Under cutting propller box
Jul 07, 2009 | Garden
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
2,256 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
