Question about Brother MFC-7220 All-In-One Laser Printer
Replace ink toner message
I just did it yesterday and now I have the same message..
.what should I do ???
  • Brother Master
  • 1,113 Answers
Re: replace ink toner message
Is it refill? if not then try leveling powder in cartridge by gently shaking, Take back as faulty, or reset new toner lever on left front of cartridge. Check toner is seated correctly in drum and drum seated correctly in machine.
Posted on Nov 08, 2007
0 characters
3 Points
Install Toner error message still displays even when replaced
If you are not using original manufacturer's replacement toner cartridges, this could be your problem, and it will not resolve. The printer and cartridge will not "talk" to each other, therefore giving you a false reading. If this is the case, you should still be able to print normally, but you will not know when you run out of ink until you actually run out, akin to a broken gas gauge in a car.
Jan 14, 2013 | Xerox Phaser Printers & Copiers
Printer is just printing a whole page of black ink and no words
Yqes that is your toner. It needs to be replaced or checked if needs to be replaced mmaybe needs cleaning asking but for the most part. If only black ink and no colors do a self diagnostic on the printer , if this is not available make sure there are no paper jams also.
Feb 21, 2012 | Ricoh Printers & Copiers
When i first start my copies on my brother dcp 1000 they are clear by the time i get to copy 20 their are dark ink smudges on the paper. It seems when the copier starts heating up they smudges happen. I...
replace the drum,
( if you have used correct toner for refill because some time it happens if two different type of toner mixed up hence assuming that you have select gud toner).
vote me if found helpful.
Aug 17, 2011 | Brother DCP 1000 All-In-One Laser Printer
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Troubleshooting 043 - Toner Cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Nov 20, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Toner probably isn't empty, but the machine shuts down at a specifc count on the cartridge regardless of actual consumption...don't you love it?
Your replacement cartridge was probably a remanufactured one and didn't have the toner reset lever properly set.
Mar 19, 2009 | Brother MFC-8460N All-In-One Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Replace/int tank toner error message
If the toner bottle has been cleaned, it might still be dirty on the top. If the bottle is new, the you need to clean up the light sensors that pass through the toner bottle.
Be blessed.
Sep 24, 2008 | Samsung CLX 3160fn All-In-One Printer
Won't copy
Are you sure it is flashing to add toner or it time to replace the drum cartridge or empty the waste toner or replace the developer or is it time for a PM. Also, did you let in run it's add toner set-up?
Sep 09, 2008 | Sharp Printers & Copiers
Brother MFC-7220 All-In-One Laser Printer Logo
195 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
