Question about HP PSC 1315 All-In-One InkJet Printer
When I want to cancel a print on my hp c4180 I press cancel and it stops only to continually restart how do I cancel the print for good
Solution by www.freaksmania.org,
We cannot turn off HP printers when the printing job is going on or it
runs out of paper,Paper Jam or Cartridge runs out of Ink or any other
reason,ie power failure.
To Cancel printing easily,
1)First plug out the Power Cable(the System tray icon will now disappear).
2)Plug out the USB Data Cable
3)Reconnect the power Cable and turn the printer on.
4)Turn the printer off again and Connect the USB Data Cable.
5)Turn on and then your existing printing Job will be Cancelled.
Solution provided by Team Freaksmania
http://www.freaksmania.org
http://www.freaksmania.org/forum
http://www.freaksmania.org/coderz
http://www.freaksmania.org/graphics
Posted on Dec 24, 2007
I have a HP F380 all-in-one printer. I just had the same problem as everyone has described above. Try this on your printer: first pull out your paper so you do not print pages and pages of unwanted info. Next, turn off your printer, unplug the USB cable on the back of the printer, go to Start, then Control Panel then Printers and double click on the printer icon you want to fix. From the top menus select Printers then cancel all print jobs. It should finally go away. Good luck!
Posted on Mar 19, 2010
I found this on the Microsoft website through Google and it is the best! It looks a little difficult, but it really isn't and it works! No unpluging or rebooting needed.
First, in case that you don’t know how printing works, here is a short
explanation. Print jobs are sent to the printer as spooled files. This
means that the files are put in a temporary location so that the
printer can access a print queue and print jobs at its own speed. If
you stop the spooler and its files, most of the time, you both cancel
printing and delete the print job.
Note To use this method, you must have Computer
Administrator status. If you are using your own printer, you most
likely have Computer Administrator status. If you are printing to a
shared printer, you might have to ask the system administrator to
cancel the print job for you.
Step 1: Start Notepad
loadTOCNode(3, 'resolution');To
stop the print spooler and its files, we will have you create and run a
script file that will automatically stop the service. This sounds
difficult, but it really isn't. Just follow these steps carefully.
a.
Click Start, and then click Run.
b.
In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
loadTOCNode(3, 'resolution');Now we will have you copy and paste some commands to the Notepad document.
a.
Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
b.
Right-click the text that you selected, and then click Copy.
c.
In Notepad, right-click in the blank document, and then click Paste.
d.
Carefully select (highlight) all the following text: C:\DeletePrintJobs.cmd
e.
f.
In Notepad, click Save As on the File menu.
g.
In the File Name box, right-click, and then click Paste.
Note
Notice that this file name differs from most other file names that you
might have seen. That is because this file is a command script file.
h.
Click Save.
Step 3: Run the command script file
that you have created the command script file, you will run it. To run
it, you will copy and paste the name of the command script file in the Run box.
a.
b.
c.
d.
In the Open box, right-click, and then click Paste.
e.
Click OK.
f.
Notice
that the Command Prompt window opens to run the command script file
that you created. Notice also that this window closes automatically
when the command script file has finished running. If you do not see
the Command Prompt window open, check that you saved the command script
file by using the correct name and that you entered the correct command
script file name in the Run box. Note
If this method does not work the first time, or if you cannot print
anything after you use this method, restart your computer, and then try
again.
If this method worked, you are finished with this
article. However, you may want to read the "Prevention tips" section to
prevent this problem from happening again.
If this method does
not work, we're sorry that this article was unable to help you. For
your next steps, you might want to ask someone for help or contact
support. For information about how to contact support, visit the
following Microsoft Web site: http://support.microsoft.com/contactus/
Posted on Jun 27, 2008
1- turn off printer
2- try clicking on the printer icon on the bottom left ( if it's there, and a box will come up with the print jobs in there. right click on the jobs itself and hit cancel.
3- turn on printer and hit cancel button on printer.
Posted on Nov 08, 2007
Press start button, programs, administrative tools, services, scroll down to print spooler, double-click and press stop, right click printer icon on task bar, refresh, it should disappear. Double click printer spooler and start back up........ cancel out of everything. Job in quene should be gone.......
Posted on Aug 11, 2008
Go to START, RUN type services.msc and ENTER. Find print spooler service and STOP.
Reboot computer
go to services.msc again and at print spooler, click on restart. This may very well work...most of the time it does for me.
Posted on Jun 20, 2008
I've tried it - it didn't help :(
Posted on Apr 23, 2008
Feb 20, 2015 | HP Office Equipment & Supplies
Jul 01, 2014 | HP LaserJet 4200 Printer
Nov 02, 2009 | HP PhotoSmart C4180 All-in-One Color...
Oct 03, 2009 | HP Office Equipment & Supplies
Jun 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Dec 05, 2008 | HP PhotoSmart C4180 All-in-One Color...
Nov 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Nov 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
May 29, 2008 | HP Photosmart C4180 All-In-One InkJet...
Dec 18, 2016 | HP PSC 1315 All-In-One InkJet Printer
12,097 people viewed this question
I selected a number of articles [which are numbered for selection] but forgot to enter only the one selected article when I clicked file-print. The printer did print that article but kept on going into previously articles. I clicked file-cancel print, then "Add Queue", and finally out of desperation turned off the printer [some of these articles are 100s of pages long!]. Whenever I want to print something else on the same website, the same old printing resumes. Help!
Same problem. Pulled the plug and let it sit for an hour. But it still wants to plrint another copy--all 80 pages of my Income Tax forms. My printer is a Deskjet 5740
hp 1400 will not cancel doc
i no longer want what is printing to print. i need to copy another document. how do i cancel it? it is currently on interrupted, that was how i got it to stop but not canceled.
