Question about Porter Cable Cable 135 PSI, 60 Gal. Oil Lube Stationary Compressor CPLC7060V
Trying to wire up my porter cabel cplc7060v for power
  • 21 Answers
DeWalt is the new owner of PC contact your local servicenter for advice or to get the schematics.
Posted on Sep 25, 2009
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
Schematics Diagrams home pc
http://www.interfacebus.com/SATA_Pinout.html
here you see how to connect the sata cabel and the power cabel.
same way for CD/DVD-WRITER.
sata narrow.signal/data.power is wide
Apr 24, 2013 | Dell Computers & Internet
On my porter cable 6 gallon air comnpressor need to know where the red black and yellow wires get plugged into
there always three wires in the power cord, the green/yellow stripe wire is for ground connection,which doesn't needed to modify.
One of the other two wire is directly connected to the power plug , and the other connects to the contact point at the pressure switch and returns back to the power plug.
if this pressure switch is not working, you have to install another kind of switch of on and off the compressor.
Sep 13, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Compressor pulley has come off, is it simply a press fit?
The pulley will fit over the shaft. There should be a key that will fit in the keyways of the pulley and the shaft when you line them up...
Then there will be two allen set screws to tighten down...one will be on the key and the other 90 degress around the shaft.
Line up the pulley so the belts align with the other pulley and then tighten everything down....you are now good to go again...
heatman101
Mar 24, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil...
I received no manual for my 60 gal. Porter Cabel air compressor (model #VT627504AJ) and I need to know the spec. for wiring.
being that its 220 on the compressor Is where I assume you are wanting to know where the wires go? There should be a terminal strip or box that has a terminal strip by each terminal there should be L1 L2 and either ground or neutral. The two hot wires one each go to the Line terminals and the ground or neutral to marked terminal.
Jan 09, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Trying to wire up my new air compressor, need help with wires.
If you are trying to connect power lines directly to the motor then stop what you are doing, I advise you refer to the owners manual for correct wiring of the compressor. I would highly advise that you seek the service of a professional to hook it up. otherwise you could damage the equipment or worse yourself.
Dec 09, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
Ok guys i got a dbr 3475 clarion cd player now i got two wires that are power yellow and blue with white strip now i know what the speakers are` but i have this red wire don't seem to go any where i power...
hi the yellow cabel is the (12volt) the blue and white is power antena and the red cabel is also a power cabel you are supposed tho putt the yellow and red cabel tho gether and connect them tho the power in the car the red cabel is a (1volt) cabel it is tho keep the memory on the stereo
Jun 08, 2009 | Clarion DRB2475
Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
May 31, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter Cable Cable 135 PSI, 60 Gal. Oil Lube Stationary Compressor CPLC7060V Logo
117 people viewed this question
Top Porter Cable Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Porter Cable Plumbing Expert? Answer questions, earn points and help others
