Ac won't go on - Heating & Cooling
    Scholar:
  • 70 Answers
Need to check for power to unit first.If you are sure you have juice then you may have a bad switch or burnt wire.If you don;t know how to check these problems don't risk your life and call a pro.
Posted on Jun 29, 2009
07 sportage. Ac clutch goes off after 5mins
Woody have refrigerant level checked may be low. have a good shop recharge A/C system if checked and found low. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FIXED Car Compressor Clutch Won Engage
The Trainer 40 When the compressor won compress
Diagnosing AC Compressor Clutch Problems
Jun 30, 2016 | AC Cars & Trucks
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
Ac fan motor won;t run
get a haynes repair manual at auto parts store or on ebay it will tell you everything you need to know to work on your own vehichle
Jan 16, 2013 | 1991 Cadillac DeVille
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Ac not working
AC's have a refrigerant pressure sensor to prevent damage to the AC compressor when there's a leak. When there's no pressure the AC shuts down and won't activate the compressor clutch. Have the AC tubing and couplings checked on leaks.
Jun 26, 2011 | 1999 Ford Taurus
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
